Jump to content
doc 58fa29622f6b7 2N7002 60 V- 300 mA N-channel Trench MOSFET Rev. 7 8 September 2011 10702.pdf
   (0 reviews)
Sign in to follow this
About This File
User Feedback
Recommended Comments
There are no comments to display.
Join the conversation
Guest
Add a comment...
×   Pasted as rich text.   Restore formatting
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Similar Content
    • By RicardoFS79
      Panda Free Antivírus
      Visualizar Arquivo Panda Free
      Uploader RicardoFS79 Enviado 14-06-2021 Categoria Software
    • By Carlos Porto
      LM358B Industry-Standard Dual Operational Amplifiers
      Visualizar Arquivo The LM358B and LM2904B devices are the nextgeneration versions of the industry-standard operational amplifiers (op amps) LM358 and LM2904, which include two high-voltage (36-V) op amps. These devices provide outstanding value for costsensitive applications, with features including low offset (300 µV, typical), common-mode input range to ground, and high differential input voltage capability. The LM358B and LM2904B op amps simplify circuit design with enhanced features such as unity-gain stability, lower offset voltage of 3 mV (maximum at room temperature), and lower quiescent current of 300 µA per amplifier (typical). High ESD (2 kV, HBM) and integrated EMI and RF filters enable the LM358B and LM2904B devices to be used in the most rugged, environmentally challenging applications.
      The LM358B and LM2904B amplifiers are available in micro-sized packaging, such as the SOT23-8 , as well as industry standard packages, including SOIC, TSSOP, and VSSOP.
      Uploader Carlos Porto Enviado 14-06-2021 Categoria Datasheets
    • By Carlos Porto
    • By Carlos Porto
      AON6912A 30V Dual Asymmetric N-Channel MOSFET
      Visualizar Arquivo The AON6912A is designed to provide a high efficiency synchronous buck power stage with optimal layout and board space utilization. It includes two specialized MOSFETs in a dual Power DFN5x6 package. The Q1 "High Side" MOSFET is designed to minimize switching losses. The Q2 "Low Side" MOSFET is designed for low R DS(ON) to reduce conduction losses. The AON6912A is well suited for use in compact DC/DC converter applications.
  • Create New...
