sandrocads
notícia Abreviação de esquema elétrico, Leitura, sequencia start
C :CAPACITOR
D IODE
F :FUSE
L :INDUCTOR
PC :POWER CAPACITOR
PD :POWER DIODES/DIODE
PL :POWER INDUCTOR
PQ :POWER TRANSISTOR
PR :POWER RESISTOR
PU :POWER INTEGRATED CIRCUIT
Q :TRANSISTOR
R :RESISTOR
T : Transformers
U :INTEGRATED CIRCUIT/BGA CHIP/EMBEDDED CONTROLER/BIOS IC,ETC
X : Terminal strips, terminations, joins .oscilator
Y : Crystal
ABBREVIATION ON LAPTOP MOTHERBOARD FOR SCHEMATIC
AC : Alternating current
ACDRV : AC adapter to system-switch driver output
ACEDET : Adaptor Current Detector
ACGOOD : Valid adapter active-low detect logic open-drain output
ACIN : Adaptor Current sensor Input
ACN : Adapter current sense resistor
ACOP : Input Over-Power Protection
ACOV : Input Overvoltage Protection
ACP : Adapter current sense resistor, positive input.
ADP+ : Adapter Positif Suplay
ADP_ID : Adapter Identity
AGND :Analog Ground
ALWP :ALWAYS ON POWER
B+ : AC OR BAT POWER RAIL FOR POWER CIRCUIT
BATT : Battery
BAT+ :BAT POWER RAIL FOR POWER CIRCUIT
BAT_DRV :Bat Fet Gate Driver
BAT_V Battery Voltage
BOM :BILL OF MATERIAL MANAGEMENT
BT :BUTTON
BT_EN :Bloototh Enable
BUZER :Connected
BYP :Baypass
CHGEN : Charge enable active-low logic input
CIN : Input Capacitor
CLK_EN :CLKOCK ENABLE
CN :CONECTOR
CRT :Cathode ray tube
CSIN :Current Sensor input Negatif
CSIP :Current Sensor input Positif
DC irect current
DM IM/DIM SOCKET/SOKET MEMORY/SOKET DDR
DOCK OCKING SOCKET
EC :Embedded Controler
EC_ON :Embeded Controler Enable
EMI :Elektromagnetik Interference(GANGGUAN ELEKTROMAGNETIK)
EN :ENABLE
ENTRIP :Enable Terminal
F :FUSE
FSEL : Frequency Select Input.
GATE : Trigger gate
GND :Ground
GP :GROUND PIN
GPI :General Power Input
GPIO :General Power Input Output
HDMI :High-Definition Multimedia Interface
ID :Continuous Drain Current
IDM :Pulsed Drain Current
IIN : Operating Supply Current
IIN(SHDN): Shutdown Supply Current
IIN(STBY): Standby Supply Current
IS :Continuous Source Current (Diode Conduction)
IVIN :Battery Supply Current at VIN pin
JP :JUMPER POINT
KBC :Keyboard Controler
LCDV :LCD POWER
LDO :Linear Driver Output
LGATE : Lower-side MOSFET gate signal
LPC :Low Pin Count
LVDS :Low-voltage differential signaling(SYSTEM PENSIGNALAN)
MBAT :MAIN BATTERY
NB :North Bridge
ODD :OUTPUT DISC DRIVE
PCI :Peripheral Component Interconnect
PGOOD : Power good open-drain output
PIR :PRODUCT IMPROVED RECORD
PSI# :Current indicator input
PVCC : IC power positive supply
RSMRST : Resume Reset
RTC :REAL TIME CLOCK
SB : South bridge
SHDN :Shutdown
SYS_SDN :System Shutdown
SPI :Serial Peripheral Interface
TD eath Time
THRM :THERMAL SENSOR
TMDS :Transition Minimized Differential Signaling(TRANSMISI DATA TEKNOLOGY)
TP :TES POINT
TPAD :THERMAL PAD
UVLO : Input Undervoltage Lock Out
V :RAIL(POWER)
V+ :Positive Voltage
VADJ : Output regulation voltage
VALW :ALWAYS ON POWER
VALWP :VALW PAD
VBAT :BATTERY POWER
VCCP :power chip(ich,graphic chips)
VCORE :POWER PROCESOR
VDD : Control power supply
VDDR :POWER DDR (VDRAM/VRAM/VMEM)
VDS :VOLTAGE DRAIN SOURCE
VFB : feedback inputs Power
VGS :VOLTAGE GATE SOURCES
VIN : Input Voltage Range
VIN :ADAPTER POWER SUPLAY(vol_in)
VL :Power Lock
VL :voltage across the load/Tegangan beban resistor
VL :Voltage Linear
VLDOIN :Power supply of the VTT and VTTREF output stage (to powerMOS).
VOT :Volt_out
VRAM :Power Memori
VREF :POWER REFERENCES/SCHEMA REFERENCE/PERMINTAAN SKEMA
VS :SUITCH POWER
VS+ :SUPPORT VOLTAGE POSITIF
VSB :POWER SWITCH BUTTON
VSS : Signal ground.
VSW :POWER SWICT
VTT : Memory Termination Voltage
VTERM :Memory Termination Voltage
VUSB :POWER USB
VGA :POWER VGA (VGPX/VGPU/VCVOD)
VGFX :POWER GRAPHIC CHIP
VREF :VOLTAGE REFERENCES
  • Like 7
  • Nice 2
    • By Alexandre Grecco
      Olá pessoal, participo de um outro forum, e criei um tópico sobre consumo de computador e outros eletrodomésticos. O objetivo é saber o que consome cada produto e o que se pode economizar no nosso dia a dia, a intenção é que vou medindo tudo que passa pelas minhas mão e vou fazendo aqui uma tabela de consumo para todos ter uma ideia o que cada equipamento gasta no fim do mês, afinal a conta de luz não anda nada barato, então vou começar aqui copiando e colando aqui o que já tenho, e vou atualizando a tabela.
      Pode parecer bobeira, mas se formos colocar tudo num papel e lápis teremos a real certeza onde mais gastamos em energia, o meu resultado aqui não me deixou muito satisfeito, pode parecer poucos para alguns ou muitos aqui, mas as contas na real assusta um pouco.
      Comprei um equipamento onde me faz leituras de consumo de energia semana passada e me chegou a dois dias atrás e resolvi hoje testar e testei hoje no meu computador, não é um super computador, mas também não é um computador fraquinho, apesar de antigo atende em tudo que preciso e sua velocidade perto de muitos PC da atualidade não faz vergonha, trata-se de uma mobo Intel DP35DP e um CPU Q6600 com 8G de memória e uma pequena VGA de 512Mb da Nvidia, tenho essa VGA pois a mobo é Off e não sou muito chegado em games, pra isso tenho aqui um PS4.
      Lembrando que o consumo pode variar de PC para PC, tudo vai depender da configuração do equipamento e seu uso!
      O PC ficou oscilando entre 130/140 Wts de consumo, mas me espantei quando abrir o navegador chegou a dar pico de 193,2Wts se não me engano, bom, em 1 hora meu PC consumiu 123Wh colocando isso num papel me saiu:
      123Wts a hora, em 12 horas de uso ele gasta 1476 kWh no mês gasta 45756 kWh somando isso pelo valor da concessionária no fim do mês ele consumiu R$ 31,99 é pouco? Tem mais!
      Fiz a leitura do PC em stand bye, ou seja desligado mas sem desligar o filtro, ele consumiu em 1 hora 3 Wts em 12 horas 36 Wts no mês 1116 kWh num total de R$ 0,78
      Também não podemos esquecer do modem, aqui tenho um da Vivo fraquinho 12v 0,5A muita gente deixa ele ligado 24 horas por dia, aqui mesmo fica 24 horas ligado, em uma hora ele consome 3Wts num dia ele gasta 72Wts no mês se vai 2232 kWh que nas contas me custa R$ 1,56
      Agora colocando tudo no papel com o PC todo e tb tenho um monitor Samsung 17P que tb está nas contas tenho gasto mensal de R$ 34,33 no mês no ano isso me custa R$ 411,96
      Agora imagina isso numa empresa de uns 10 computadores e 9 horas de trabalho lembrando que muita empresa na hora de almoço deixa seu PC ligado, sai no ano R$ 4.119,06 esse valor mensal numa empresa sai R$ 343,30 isso porque se não me engano o valor da tarifa empresarial é maior que residencial, e a minha aqui é residencial.
      Depois disso fiz outra conta, o que eu posso economizar só no PC, seria desligar o PC completamente e também o modem/rotador só com isso economizo R$ 1,56 e desligando o filtro ganho mais R$ 0,78 e no ano tenho uma economia de R$ 28,08! Já numa empresa a economia seria no ano de R$ 280,80 que sai mensal R$ 23,40 a menos na conta!
      Depois desse teste hoje com o PC vou atualizando aqui tudo que vou medindo, assim saberemos onde gastamos e onde podemos economizar!
      Computador em casa Voltagem 110V
      Valor de consumo no mês R$ 34,33 no ano = R$ 411,96
      Valor de economia no mês R$ 2,34 no ano = R$ 28,08 -
      Economia de 6,80%
      Atualização em 31/10/19
      Geladeira em casa Voltagem 110V
      Geladeira Brastemp Ative Frost Free 429L Modelo BRM50NBANA
      Valor de consumo no mês em modo médio R$ 61,38
      Valor de consumo no mês em modo mínimo R$ 33,29
      Economia de 54,25%
      Ventilador em casa Voltagem 110V
      Ventilador Arno Silence Force
      Valor de consumo no mês em modo turbo R$ 20,46
      Valor de consumo no mês em modo normal R$
      Valor de consumo no mês em modo dormir R$
      Fritadeira Walita em casa Voltagem 110V
      Fritadeira Walita
      Valor consumo no mês R$ 3,68
      Atualização em 04/11/19
      Máquina de lavar e secar Samsung Eco Bubble 11K Digital Inverter
      Máquina Lavar Samsung voltagem 110V
      Valor de consumo no mês R$ 9,90
      Letreiro Digital Semi SL1021V 105V/235V - Voltagem 110V
      Letreiro Digital
      Valor consumo no mês R$ 10,66
      Atualização em 06/11/19
      Chuveiro Lorenzetti Duo Shower 7500W Voltagem 220V
      Chuveiro
      Valor consumo no mês R$ 49,28
      Atualização em 11/11/19
      Micro-ondas Brastemp BMS25ABHNA 18L - Voltagem 110V
      Micro-ondas 18L
      Valor consumo no mês R$ 2,10 - 5 minutos diários
      Valor consumo no mês R$ 6,30 - 15 minutos diários
      Valor consumo no mês R$ 25,22 - 1 hora de uso diário
      Atualização em 13/11/19
      Micro-ondas Brastemp BMS46BBHNA 30L - Voltagem 110V
      Micro-ondas 30L
      Valor consumo no mês R$ 2,05 - 5 minutos diários
      Valor consumo no mês R$ 6,15 - 15 minutos diários
      Valor consumo no mês R$ 24,60 - 1 hora de uso diário
      Notebook Asus VivoBook X510U i5-7200U
      Notebook
      Valor consumo no mês R$ 6,93
    • By Marcão de Souza
      Posto mais um site de diagramas de reparo de TVs, é provável que muitos dos modelos existam no Brasil, vale a pena conferir, é um farto material. Link:
      Mais um site repleto de manuais e diagramas de serviço para televisores Smart das mais variadas marcas. Link:
      Posto mais um site, com farto material para download de manuais de serviço e diagramas dos mais variados modelos de telefones celulares. Link:
