warsztat
bios Dell Optiplex 9020 AIO ipplp-az
Posted (edited)
Hi, i need bios & ec ipplp-az in Dell Optiplex 9020 AIO
after push power switch no screen, flashes led hdd, dell test start (menu + power) == screen test ok, after test no scereen
após pressionar o botão liga / desliga sem tela, LED de HD piscando, iniciando o teste Dell (menu + energia) == teste de tela ok, sem tela após o teste
all the best to everyone
Edited by warsztat
@warsztat
To download, you must have (free) or
To receive help, open a new topic in the corresponding area
Topic title should follow this pattern: Brand and Model + Board Template + Defect.
Please also inform all the tests already done.
Here are some links that may help:
Posted (edited)
Hi, I download this bios
 but not work, still no display, now led orange flashes 3 & 7,original bios no display but led blink white showing loading data from hdd? so it looked like
code 3 & 7 orange indicates bad RAM board but i tested this RAM difrent computer shes work good.
maybe I'm doing something wrong, maybe there is a procedure after rewriting the bios system?
I moved ME from original bios to new one, no orange flashes but still no image on screen :(
Edited by warsztat
@warsztat this area is only for file request, to receive help, open a new topic in the
    • By gabrielnote
      Olá pessoal!
       Regravei a BIOS desse cara, porém agora ele fica com essa mensagem TPM Devide is not detected e só clicando OK para sair.
       Tentei fazer alguns Downgrades e mesma coisa.
       Tentei achar a configuração dentro da BIOS onde fica security mas não está lá.
        Agora fiquei sem saída.
       Alguém com problema semelhante?
      @FDONATO Você que entende muito de BIOS. Sabe qo que posso fazer nesse caso?
    • By Icl Setelagoas
      PHITRONICS P7i45GC-M+ v1.0a
      Backup de placa funcionando perfeitamente.
      Uploader Enviado 06-12-2021 Categoria You are not allowed to view links. Sign in or sign up.
    • By Icl Setelagoas
    • By Daniel Lyra
      Olá, Estou com um Notebook Dell DELL Inspiron 5458 onde o mesmo está com uma das trilhas que vai para o TrackPad danificada,
      O mesmo estava funcionando normalmente porem  depois de alguns meses o o notebook apago e só funciona sem o track pad conectado.
      Infelizmente não tenho certeza se o track pad está em curto ou se algum setor da placa está danificado e não faz ele ligar quando o trackpad esta conectado.
      Estou precisando do esquema elétrico ou a Board View, para checar as tensões que vão para o trackpad, pois não tenho outro pra testar ou se com o tempo pode vir a danificar o novo por alguma alimentação errada.
      Desde já muito obrigado.
