devolvido Brother 1610WE Teflon cylinder
Leo Tenora
Hello, such an unpleasant thing happened to me. I didn't notice when specifying the print that I had a document foil in the path and it was pulled into the printer and all the way to the fusing unit. Unfortunately, I used scissors to remove it and damaged the Teflon cylinder, see photo.
How can I fix this.
What will happen if I use a cylinder with this problem.
Thank you
So it will be seen on paper every time?
The problem is that you can't get a new one for this model, but you probably have to buy the whole fixed unit :(, which costs a lot of money.
I couldn't find it separately.
Does anyone have a service manual please? Brother 1610WE
Editado: por Leo Tenora
@Leo Tenora Good afternoon.
Please remove the gear on the right side and see if the roller slots are the same as in this ad...
If they are the same, you can buy.
Good luck!
