dúvida Lenovo G40-80 - ACLU3 / ACLU4 UMA MN-A362 Rev 1.0 - does not turn on, but if the led states on and does not consume
Edwar estiven peña gaviria
I have a levono g40-80, which does not turn on, shows that the power led and battery are working, but the equipment itself does nothing, I have a laboratory source and the source tells me in the amperage that it is consuming 0.012 A without the battery, with battery are 1.038A and the 20v are maintained, estor a little blind since I do not have the schematic,  if anyone is so kind to help me i would appreciate it very much.
in the case of the 19v if depsues of the mosfet if in the piece that has the numbering Pr301 I have the 19V (both before and after the mosfet), and in the case of the 3.3 and 5v if I also have them
Editado: por Edwar estiven peña gaviria
1: Power button, if you have 3.2V
2: The power button if it goes to 0V
Note that I hope is useful: In some touches (not all) that I do to the power button does not go down to 0v but goes down from 3.2v to 1.25v and returns to 3.2
Pin 33 of the Super IO marks 5.0v
Pin 75 marks 3.3V
Pin 100 3.3V
Pin 105 marks 0.0v
pin 110 cuandro preciono the power button pass from 3.3v to 0 and to 3.3v again
I write all this since I do not have the schematic, so these measurements are what I know in a way General, and I do not know if the data are explicitly what you are requesting.
and I thank you for the help
Correction
@Edwar estiven peña gaviria temos o esquema dessa placa no fórum:
Para que possamos lhe auxiliar é necessário que você retorne com os valores das tensões solicitadas da forma mais detalhada possível. Veja que no esquema temos a sequência de start, que descreve como a placa liga. Siga a sequência e retorne com os valores encontrados. Grato.
En 15/7/2023 a las 16:53, WJinformatica2016 dijo:
super io pins 14, 108, 109, 110, 111,
I'm really sorry if I don't answer you right away and I will recover (hospital) more or less, but I'm already close to the plate, I already try the pins you mention
 Pin 14 dial 3.37 by pressing button 3.37
Pin 108 0.00 by pressing 0.00V button
Pin 109 3.39V by pressing button 3.39V
pin 110 3.36 Pressing button 0.00v
Pin 111 3.39 by pressing button 3.39V
41 minutos atrás, Edwar estiven peña gaviria disse:
everything is correct in my see.
so i think you can record the bios and see how the board will behave my friend.
En 24/7/2023 a las 14:18, Carlos Porto dijo:
@Edwar estiven peña gaviria Incluso sin un esquema, puede verificar al menos lo básico. Comience por rastrear las señales que se muestran en el diagrama de flujo de la publicación # 9. Compruebe el SIO ya que todos los signos están relacionados con él.
Espero comentarios. Agradecido.
ready I get into it, and thank you very much
En 24/7/2023 a las 14:43, WJinformatica2016 dijo:
ok I will try looking for the .bin of the board and I have 2 to try, and again thanks for your help
