leandro_arb
Okidata B4600
Cesar Jose    32
Tirei do service manual dela, ve se ajuda.
Synchronous serial I/O error or I/F timeout between printer and optional tray
(ERROR 180, 182)
•Is an option tray (High Capacity Second Paper Feeder or Multi Purpose Feeder) being used?
•Yes Is the cable between the main control board and the optional tray being connected
properly?
•No Connect the cable properly.
•Yes Replace the main control board.
•Has the problem been solved?
•No Check the problem by following the Multi Purpose Feeder maintenance manual
of Appendix F or the High Capacity Second Paper Feeder maintenance manual
of Appendix G.
•Yes End
•No Replace the main control board.
Criar uma conta
Crie uma nova conta
Entrar
Entrar Agora
