Discussão sobre ativação Simplo 2022 e Dicatec 3.5
  • Respostas 307
  • Visualizações 60,5k
  • Criado
  • Última resposta
Principais posts deste tópico
Most Popular Posts
Imagens Postadas
  • 4 semanas depois...
I don't speak Portuguese, but even from the title and category it's clear this tutorial is focused on activating the 2022 Simplo and Dicatec 3.5 automotive diagnostic software. Posting guides like this in a dedicated automotive electronics section is helpful because it keeps troubleshooting and activation information in one place for technicians who use these tools. It would also be useful if the tutorial included common installation issues and compatibility notes, since those are often the biggest hurdles for first-time users. Você não tem permissão para visualizar links. Faça login ou cadastre-se.
@Ihsan Khan
Hello Ihsan Khan,
I see you've jumped into a discussion about activating Simplo 2022 and Dicatec 3.5. It's great that you're looking to contribute and share your thoughts!
This topic is quite old, and it seems like the original conversation was about users requesting activation keys for this software. Since you've posted a comment that's more of a general observation about the tutorial and its potential improvements, and considering the age of the topic, it might be best to start a new thread for your specific points.
To make sure your insights reach the right people and to avoid confusion, please consider creating a new topic. This will help keep the forum organized and ensure your suggestions are seen by active members who can discuss them further.
When you create a new topic, here are a few pointers to keep in mind:
If you'd like to start a new discussion related to automotive software or tutorials, you can do so here:
Thanks for being a part of the community!
Sobre o link externo: @gabriel prado usus, arquivos de BIOS, firmwares, esquemas, BoardView, dumps, ferramentas ou outros downloads técnicos não devem ser compartilhados por links externos em drive.google.com. Para manter o acervo seguro, organizado e disponível para a comunidade, faça o upload pelo Gerenciador de Arquivos do fórum.
Envie o arquivo por aqui: Enviar arquivo no EletrônicaBR. Veja também o guia: Uploads: aprenda como enviar arquivos para o fórum.
Links úteis:
Criar minha apresentação
Criar novo tópico em Eletrônica Automotiva (Módulos e ECU)
Precisava muito do Dicatec mas não tenho créditos para baixar, alguém consegue dar uma força aí dando o joinha ?
Olá, @vtrwdl!
Pelo que vi, você está precisando de ajuda para ativar o Simplo 2022 e o Dicatec 3.5. Entendo que você não tem créditos suficientes para baixar o que precisa e está pedindo uma força com um "joinha".
Essa discussão sobre ativação de programas é bem comum por aqui. O pessoal que tem acesso ao programa, como o @tiojeca jeca, costuma gerar as chaves de ativação para ajudar a comunidade.
Como você tem 0 créditos e 11 posts, ainda não atingiu o limite para gerar muitos créditos apenas com participação. Para conseguir mais créditos e ter acesso a mais recursos do fórum, você pode participar ativamente nas discussões, compartilhando seus conhecimentos e ajudando outros membros. Cada joinha que você recebe em suas postagens vira créditos para você!
Se precisar de mais detalhes sobre como funciona o sistema de créditos e como ganhar mais, dê uma olhada aqui: Sistema de Créditos do EletrônicaBR
Além disso, como você é novo por aqui, seria ótimo se pudesse se apresentar para a comunidade. Isso ajuda bastante a gente a te conhecer melhor e a te dar um suporte mais direcionado: Apresente-se aqui!
Continue participando e compartilhando suas experiências, que aos poucos você vai liberando mais acesso e conseguindo tudo o que precisa para seus reparos!
Links úteis:
Criar novo tópico em Eletrônica Automotiva (Módulos e ECU).
Olá, @NATANSALLES.
Notei que você respondeu em um tópico que já tem bastante tempo de criado. Antes de enviar uma mensagem, é sempre uma boa prática conferir a data das postagens anteriores para manter a organização da comunidade.
Como o seu pedido parece ser um caso individual de suporte ou solicitação de ativação, o ideal é que você crie um tópico novo e exclusivo para o seu equipamento ou dúvida na área correspondente do fórum.
Para dar os primeiros passos na comunidade e liberar todas as interações, não deixe de fazer a sua apresentação pessoal na área de Apresentações.
Depois, você pode iniciar um novo tópico diretamente em Eletrônica Automotiva (Módulos e ECU) ou explorar o índice geral do fórum para encontrar a seção mais adequada ao seu caso.
Link útil:
