Problema com botão em projeto com RFID + Servo.
Olá ! Abraço a todos. Agradeço aos Amigos pela atenção e ajuda.
  Consegui resolver o problema do botão para acionar o servo, utilizando esse sketch com pequena modificação.
// this constant won't change:
const int  buttonPin = 2;    // the pin that the pushbutton is attached to
const int ledPin = 8;      // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0;  // counter for the number of button presses
int buttonState = 0;        // current state of the button
int lastButtonState = 0;    // previous state of the button
unsigned long intervalo = 0;
void setup() {
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  // initialize the LED as an output:
  pinMode(ledPin, OUTPUT);
  // initialize serial communication:
  Serial.begin(9600);
void loop() {
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH){
      // if the current state is HIGH then the button
      // wend from off to on:
      buttonPushCounter++;
      intervalo = millis();
      Serial.println("on");
      Serial.print("number of button pushes:  ");
      Serial.println(buttonPushCounter);
    } else {
      // if the current state is LOW then the button
      // wend from on to off:
      Serial.println("off");
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state,
  //for next time through the loop
  lastButtonState = buttonState;
  // se passar mais que 2 segundos entre os pressionar de botões, ele volta a zero e precisa pressionar duas vezes de novo
  if(millis() > intervalo+2000){
  // turns on the LED every four button pushes by
  // checking the modulo of the button push counter.
  // the modulo function gives you the remainder of
  // the division of two numbers:
  if (buttonPushCounter  == 5) {
    digitalWrite(ledPin, HIGH);
    delay(2000);
    digitalWrite(ledPin, LOW);
  //else {
    //digitalWrite(ledPin, HIGH);
Olá
Tente removendo esta parte do código: linhas(190 até 195)
      myservo.write(0);    //Move o servo para o angulo de 0 graus
      delay(4500);        //Delay para o servo atingir a posição
      myservo.write(90);  //Move o servo para o angulo de 90 graus
      delay(500);          //Delay para o servo atingir a posição
Acho que assim vai funcionar.
Olá ! Muito agradecido pela ajuda, mas se eu retirar essa parte, quando usar uma tag cadastrada e chamar a função void efeitoPermitido() , o servo não vai funcionar. O botão é para acionar o servo diretamente. Mas não encontrei uma maneira de inibir o servo se ficar com o botão pressionado por mais que três segundos por exemplo. Quero que ligue só dando os cinco pulsos curtos com menos de dois segundos.
      Grande abraço.
