Toshiba c660 la-6842p powers off rapidly
I have i3 la-6842p that powers itself down rapidly even in bios after less than 1 minute. I have swapped Cpu/Ram fitted new thermal paste changed power supply/bench supply but still the same. Where is the best place to start?.
Many thanks.
Check the 17435 maxim ic, those toshiba laptops usually burn that maxim along with the 4410 fet
Check the 17435 maxim ic' date=' toshiba laptops Those usually burn it along with the maxim 4410 fet[/quote']In what section? There does not seem to be either of those components on this board
the 4410 fet is very near the power cable connection and the maxim is on the opposite side of the board almost in line with that mosfet
No sorry I think you are referring to a different board. These do not exist on this board can you say which component numbers they are like Uxxx PQxxx
what board do you have, ive just opened a laptop of that precise model and the parts are exactly where i said, it might be a different motherboard model tho
