Tudo que igopower publicou
  1. A portable power station is a simple battery-operated backup device that gives you power output when you need it. Once the portable power station is fully charged, you can take it with you on long trips without worrying about your electrical equipment as you can plug them into the portable power station anytime, anywhere.Product application fields include: medical equipment, emergency disaster relief, outdoor activities, drone battery life, self-driving tours, household electricity storage, lighting, office, fishery, military, power-free mountainous areas, pastoral areas, field investigations and other electricity fields. Outdoor power bank portable power station is lightweight and compact, and uses lithium iron phosphate batteries that are environmentally friendly, small in size, large in capacity and light in weight as strong support to ensure that important loads can continue to work and have sufficient power supply. It is specially designed for outdoor emergency. It combines light weight, high capacity and high power. It has over-voltage, overload and short-circuit protection design, and super-power pure sine wave output. If you are buying a portable power station, first check the following properties: Battery capacity: Since every portable power station is powered by a battery, you must check the capacity of the battery before purchasing. A high-capacity battery will be able to provide more power for a longer period of time than a low-capacity battery. Battery capacity is expressed in watt hours. Power rating: The power rating of a portable power station is basically the maximum power output you can draw. This power rating is mentioned in watts. The higher the value, the more powerful devices you can connect (eg toaster, mini heater, etc.). It is important to keep the power rating in mind as you cannot get more power from the power station than this rating. Portability: The primary goal of a portable power station is to carry it around for a variety of applications. If the power station is too heavy or bulky to carry with you, a portable power station will not be convenient for long trips. So make sure your device is light and compact.
  2. A portable power station is a simple battery-operated backup device that gives you power output when you need it. Once the portable power station is fully charged, you can take it with you on long trips without worrying about your electrical equipment as you can plug them into the portable power station anytime, anywhere.Product application fields include: medical equipment, emergency disaster relief, outdoor activities, drone battery life, self-driving tours, household electricity storage, lighting, office, fishery, military, power-free mountainous areas, pastoral areas, field investigations and other electricity fields. Outdoor power bank portable power station is lightweight and compact, and uses lithium iron phosphate batteries that are environmentally friendly, small in size, large in capacity and light in weight as strong support to ensure that important loads can continue to work and have sufficient power supply. It is specially designed for outdoor emergency. It combines light weight, high capacity and high power. It has over-voltage, overload and short-circuit protection design, and super-power pure sine wave output. If you are buying a portable power station, first check the following properties: Battery capacity: Since every portable power station is powered by a battery, you must check the capacity of the battery before purchasing. A high-capacity battery will be able to provide more power for a longer period of time than a low-capacity battery. Battery capacity is expressed in watt hours. Power rating: The power rating of a portable power station is basically the maximum power output you can draw. This power rating is mentioned in watts. The higher the value, the more powerful devices you can connect (eg toaster, mini heater, etc.). It is important to keep the power rating in mind as you cannot get more power from the power station than this rating. Portability: The primary goal of a portable power station is to carry it around for a variety of applications. If the power station is too heavy or bulky to carry with you, a portable power station will not be convenient for long trips. So make sure your device is light and compact.
