    52 [ Doar ]
Tudo que hom_jr publicou
  1. Obrigado a todos. Troquei o Windows 8 pelo 7. Cliente ficou satisfeito. Instalação ocorreu normal.
  2. Obrigado Seta , Porém não deu certo.
  3. Error in action CheckForPreviousInstall can't read "tmp(Dir)": no such element in array while executing "list $mtime $id $tmp(Dir)" (procedure "::InstallAPI::ReadInstallInfo" line 39) invoked from within "::InstallAPI::ReadInstallInfo -prefix PreviousInstall -array PreviousInstallInfo" (procedure "::InstallJammer::ReadPreviousInstall" line 9) invoked from within "::InstallJammer::ReadPreviousInstall" (procedure "::InstallJammer::actions::CheckForPreviousInstall" line 2) invoked from within "::InstallJammer::actions::$component $this" Error in action CheckForPreviousInstall can't read "tmp(Dir)": no such element in array while executing "list $mtime $id $tmp(Dir)" (procedure "::InstallAPI::ReadInstallInfo" line 39) invoked from within "::InstallAPI::ReadInstallInfo -prefix PreviousInstall -array PreviousInstallInfo" (procedure "::InstallJammer::ReadPreviousInstall" line 9) invoked from within "::InstallJammer::ReadPreviousInstall" (procedure "::InstallJammer::actions::CheckForPreviousInstall" line 2) invoked from within "::InstallJammer::actions::$component $this" while executing "$obj execute" (procedure "::InstallJammer::ExecuteActions" line 69) invoked from within "::InstallJammer::ExecuteActions $id -when $when" (procedure "::InstallJammer::NextCommand" line invoked from within "::InstallJammer::NextCommand .wizard 5C5B9375-5DCF-DF7A-079C-9042A8BEA143" ("uplevel" body line 1) invoked from within "uplevel #0 [string map $map $command]" (procedure "_eval_command" line 22) invoked from within "_eval_command $path $cmd" (procedure "Wizard::next" line 9) invoked from within "Wizard::next .wizard 1" ("eval" body line 1) invoked from within "eval [linsert $args 0 Wizard::$cmd .wizard]" (procedure ".wizard" line 1) invoked from within ".wizard next 1" invoked from within ".wizard.buttons.b1:cmd invoke" ("uplevel" body line 1) invoked from within "uplevel #0 " (procedure "TTKButton::invoke" line 2) invoked from within "TTKButton::invoke .wizard.buttons.b1" ("eval" body line 1) invoked from within "eval [linsert $args 0 TTKButton::$cmd .wizard.buttons.b1]" (procedure ".wizard.buttons.b1" line 1) invoked from within ".wizard.buttons.b1 invoke " invoked from within ".wizard.buttons.b1:cmd instate {pressed !disabled} { .wizard.buttons.b1 state !pressed; .wizard.buttons.b1 invoke }" ("uplevel" body line 1) invoked from within "uplevel #0 $args" (procedure "TTKButton::instate" line 2) invoked from within "TTKButton::instate .wizard.buttons.b1 {pressed !disabled} { .wizard.buttons.b1 state !pressed; .wizard.buttons.b1 invoke }" ("eval" body line 1) invoked from within "eval [linsert $args 0 TTKButton::$cmd .wizard.buttons.b1]" (procedure ".wizard.buttons.b1" line 1) invoked from within ".wizard.buttons.b1 instate {pressed !disabled} { .wizard.buttons.b1 state !pressed; .wizard.buttons.b1 invoke } " (command bound to event)
  4. Estou tendo dificuldade de instalação do programa da Receita Federal "IRPF 2017", no Windows 8. Firewall está desabilitado Antivirus está desabilitado. Ocorre o seguinte erro em anexo na foto.
  5. Não achei até agora.
  6. Sobre celular samsung J7 2016, toque de chamada muito baixo existe alguma solução ? Existe um lugar que posso baixar toque para testa no celular de confiança. Testei todas a opções de fabrica de toque.
  7. Tenta também remover a bateria ,por tempo e depois liga para ver que volta ao normal.
  8. Obrigado pela correção.
  9. Escolhi o vídeo aleatoriamente, peguei o primeiro que estava a disposição no youtube.
  10. Truque que inclui ‘ss’ na URL e baixa vídeos do YouTube, sem uso de programas. Basta que o usuário adicione as letras "ss" na URL do vídeo para salvá-lo no computador. Na barra de endereços, mude o URL do vídeo adicionando as letras SS antes da palavra “youtube” e tecle Enter. Por exemplo:https://www.youtube.com/watch?v=wt8EJrKjcsA Fica assim: https://www.ssyoutube.com/watch?v=wt8EJrKjcsA
  11. Estou precisando do dvd Windows seven com todas as versões . Alguém tem como disponibilizar .
  12. Não teve jeito de fazer o downgrade. Instalei o windows 8 no lugar do windows 10. A instalação criou a pasta windows.old. Deu tudo certo. Obrigado.
  13. downgrade windows 10 para windows 8 sem perder documentos. obs: não existe a pasta windows.old marca notebook: Dell inspiron 14 3000 series
  14. http://www.gearbest.com/measurement-analysis/pp_167152.html
  15. Estou precisando da Trava do Cabo LAN do notebook samsung 700 z , não consigo achar para comprar.
  16. Pode deletar o tópico. Quiz tentar voltar mexer com impressora de novo não deu muito certo. Sou do tempo da hp serie 600 ,700 e 800 epson matricial. Um companheiro disse que o defeito tava no conjunto tração do papel, trocou uma engrenagem. Obrigado pela atenção.
  17. Hp deskjet 3650 não puxa papel.
  18. Tenho uma tv lg 42lw5700-sa , existe um Adaptador Wireless compatível com preço mais em conta? Este modelo da Lg anwf100 custa na faixa de 200 reais.
  19. Tenho um modem speedstream 4200 , funciona normalmente vale a pena trocar por um modelo mais novo?
  20. Instalei uma placa rede rede nova, desativei a placa rede on-board. Funcionou normalmente. Obrigado a todos.
  21. Vou instalar o linux (Ubuntu), num hd, e já tenho windows 8 em outro hd . Qual o procedimento que tenho que tomar quando ligar o computador ,para qual sistema usar. Tenho que instalar algum programa. ou vai ser automaticamente.
  22. Tenho 01 computador "win -7 " na rede não reconhece o computador com windows xp. Tenho 05 computadores "win -7 " que reconhece o computador com windows xp.
  23. Todos os computadores com windows 7 estão desativados compartilhamento por senha. Obrigado.
  24. Todos pertencem ao mesmo grupo de trabalho. E estão compartilhados.
  25. Não,estou usando o Avira free.
