Xbox 360 Slim corona 4gb U5A5 and U5A4
Hi
Please Can someone upload photos of c5a5 and c5a4
I have corona 4gb board
It seems like the pads and the top is all joined
also the bottom is joined
there are not separate pads for the two capacitors
Please someone upload specs for these
Thanks
i need to see under the capacitors
c5a5 and c5a4
In my board the top pads are all joined as the bottom
There are not separate pads
I need to verify if it is correct on my board
thanks
Also does anyone know the voltage and farad to replace these pls
@xbox1 , the 2 capacitors are on the same line (5v) (Together.). You can use any ceramic capacitor of the same size (preferably some circuit 5v or higher)
what about farad
how many uf
Someone must know the specs please
Can I use
6.3V
0.1 UF
or
can i go higher in farad and keep same voltage or higher in voltage
Thanks
Hi
So Can I use any uf and any voltage higher than 5v
Please confirm
Thanks
friend, just for xbox testing, do not need those 2 capacitors, they're in the circuit for protection. Use some identical motherboard ceramic capacitor, it can be capacitor of 5v ~ 50v, remembering that this line can only enter up to 5v (max 5v). I do not have the value of the capacitor as it just retreats it from motherboard junk from xbox.
ok but can i replace with 10uf, 6.3v
will this be ok
I dont have another dead board to take identical ones
will these work
I prefer to replace them to leave blank
please confirm
thanks
hello, you can use it, but when you plug the power supply into the motherboard, make sure you have stable 5v on this line.
@sh4d0w4224 Thanks friend
