Postado 28 de Março de 2017 9 anos Boas pessoal, Eu estou a procura de alguma ajuda para resolver uns exercícios de arduino para a escola. Pois so me falta a disciplina de microprocessador para finalizar o curso.. e como tal nos nessa disciplina temos um modulo que e aprender a programar o arduino! Eu tenho aqui alguns exercicios que não conseui resolver, se alguem me conseguir ajudar a fazer e tentar meter nos comentarios uma breve explicação agradecia imenso. Eu sei que quem domina arduino e a programação vão achar estes exercícios muito facil de fazer ... EX.1 Read potentiometer & show value in 7- segment display Read value from potentiometer (0-1023) Display corresponding value (00-99) in 7- segment display Hints: 1) You have to convert a decimal value (0-99) into BCD. Convert each digit at time. For example • 75: you first convert 7 into BCD, then you convert 5 into BCD 2) To display 2X7-segments in the IDL800A you need to “multiplex” the 7-seg display. For example • 75: to display 7, you set the BCD code for 7, “activate” left 7-seg display (cathode low), “deactivate” right 7-seg display (cathode high) and wait sometime (about 10 ms) • Then you set the BCD code for 5, “deactivate” left 7-seg display, “activate” right 7-seg display and wait sometime (about 10ms) EX.2 Count up/down: Display number on 7 segments • Start at 00 If push button A is pressed • Count up If push button B is pressed • Count down When the counter is at 99, and button A is pressed, display must go to 00. When the counter is at 00, and button B is pressed, display must go to 99. EX.3 Counter up and reset: Display number on 7 segments • Start at 00 Every second the counter goes up (do NOT use the function delay()) If push button A is pressed counter is reset, i.e. goes to 00 (use interrupts) EX.4 Read potentiometer: Read potentiometer Use LEDs to display value of pot LED 1: pot 1/8 max value LED 2: pot 2/8 max value LED 3: pot 3/8 max value LED 4: pot 4/8 max value LED 5: pot 5/8 max value LED 6: pot 6/8 max value LED 7: pot 7/8 max value LED 8: pot equal max value Obrigado pessoal
