sa200f3v250.exe
sa200f3v250.exe
View File
Release Notes
BIOS V2.20, V2.30, and V2.40 change points were combined with BIOS V2.50 change points.
Change History
Version 2.50 - 2008-12-19
ModifIed: ICH8M SATA workaround for B2 stepping.
Enabled the ICH8 CRID function due to an ICH8M version B2 change.
Fixed: The Internal keyboard repeat speed can not be changed.
Modifed: The EC Level 0 Fan Speed is the same as Level 1 Fan Speed for shutdown workaround.
Fixed: Some LANs can not be recognized during S4/S5.
Updated Robson code for INTEL IMSM driver.
Version 2.10 - 2008-03-24
Updated the microcode to Penryn CPU Signature 10676h, Revision ID 60C.
Updated the Phoenix BIOS code for a Penryn THERMTRIP issue.
Updated the Intel MRC code to V104.
Increased the EBDA size to allow certain HDD Encryption software to run.
ICH8 BSU V1.8 updated to fix a "SATA Initialization from LPM state" issue.
Updated the Intel SantaRosa PPM reference code to V1.90.
Version 1.90 - 2008-01-30
Added: Computrace support.
Updated: ATI VBIOS for Windows XP to maintain the display mode after pressing the Fn+F5 hot-key combination.
Corrected: The master password can not be set with HGST Bronco HDDs.
Corrected: The "Pause Break" key does not function while the Toshiba logo is displayed.
Corrected: Black screen after wake-up with some USB keyboards.
Corrected: Power on problem with some MXIC Flash ROM modules.
Added: New model support.
Updated: PPMSR to version 170.
Updated: Brightness table.
The "Phoenix USB Crisis Key Detecting" function was disabled to correct an intermittent Microsoft USB Basic Optical Mouse hang.
Corrected: System hang with certain Golan cards.
Updated: Computrace Absolute OPTROM Build 864.
Modified DMI Type-12 to support I/O Data RAM Modules without complete SPD information.
Updated: Video RAM size for Windows XP.
Added Penryn support including the Intel false thermal trip version 0.7 workaround.
Updated: CPU microcode.
Version 1.40 - 2007-08-10
Disabled: SB COM A, COM B, LPT, and FDD IO resource decoding to prevent GPS card resource conflicts.
Updated: TOSHIBA Logo.
Disabled: ASPM / L1 with Robson.
Added: Support for the MX25L800 flash part.
Corrected: Black screen displayed after the computer is woke up by a USB 1.1 device.
Updated: ATI VBIOS "BR25228P" to remove an unnecessary string.
Corrected: An error message is displayed when installing TOSHIBA common modules on Windows XP.
Export Control and EULA
Use of any software made available for download from this system constitutes your acceptance of the Export Control Terms and the terms in the Toshiba end-user license agreement both of which you can view before downloading any such software.
  • 5 anos depois...
@morriss
Para fazer downloads é necessário ter  Créditos ou Assinatura VIP.
Para conseguir ajuda, inclusive para baixar o arquivo que precisa, abra um novo tópico na área correspondente.
Manual do Usuário
Sistema de Créditos do EBR
