flash kb9052 com ch341a
I want to program my EC/Super IO KB9052 chip with the CH341A programmer. After a lot of research, I discovered that it is possible with a flashrom and the CH341A programmer. But I can't find the right flashrom that supports ENEPROG. Does anyone have any ideas? Thanks.
So... Good morning.
Just now I saw that you are an international user, you can chat to me in english if you want.
You already found the right flashroom and driver I think.
I have compiled it some time ago, and I assure you that it works in windows 10/8/7 don't know about the 11 version.
As you do not come back to say something in the topic we previous chat, I come to see your activities and found this topic.
You should look at the connections that you made between the board and programmer, it is preferable to use, the thin wires that are used in the old IDE 80 vias cable, or something like it, people have tried with ethernet cables wires including me and the results are not good.
You could also try to run the powershell and, or, CMD as administrator.
Another user that uses regular basis this flashrom and driver confirmed that this problem is probably related to bad connections between the programmer and the board.
If you still need help chat with me again.
