Tudo que xbox1 publicou
  1. xbox1
    em análise Fat ps3, cok-002 12v short
    hi all
  2. xbox1
    Hi I understand that but I dont know Portuguese Google translate will translate this to Portuguese I will really appreciate the help from this forum as I really want to get this working again please Thanks
  3. xbox1
    Hi I have an old FAT ps3. cok-002 I have the blackout problem. Where it turns on and off but will not turn back on for a while but will just do the same thing after 20 mins or so I checked the motherboard and found a short on the 12v line The console was hardly used and not under stress was working ok I have removed lots of ceramic caps and the short is not going I will greatly appreciate some help please Thanks in advance
  4. Please help people
  5. @sh4d0w4224 looked. Cannot find Do you have one you can send pls
  6. Does anyone have a spare ksb for a corona they can send to me pls @sh4d0w4224 i dont have another ksb spare what else can i use or do this was working fine and ok
  7. @sh4d0w4224 would a reflow work
  8. @sh4d0w4224 i dont have another chip
  9. @Neo ok thanks, i thought maybe it was easier to understand for separate posts, didnt want to confuse everyone
  10. @sh4d0w4224 voltages you asked for see pic I still think its something else as this was working perfectly
  11. @sh4d0w4224 @sh4d0w4224 i dont think it is a nand chip gone or south bridge gone i just need some help maybe mosfet or resistor or cap
  12. @sh4d0w4224 the southbridge isnt getting hot i think its just a bad trace can someone tell me where i can use an alternative point for pin 1 pls
  13. @sh4d0w4224 yes but everything was working ok and I am not getting voltage on pin 1 i dont know why all my standby voltages are ok
  14. I am on the 4gb corona I believe this is the corona V2, according to the table below ok thanks for this but could you help me for getting 3v on pin 1 please @Tanograu please can you help me more
  15. I am on the 4gb corona I believe this is the corona V2, according to the table below
  16. Hi Can some one tell me the voltage on the U1D1 pins from a working corona board please Please can some one verify what the voltage should be on pin 1 on U1D1 nand From My research U1D1, pin 1 is VDD but I am not getting any voltage I have attached image, (taken from google, not mine), highlighted in yellow is where the damage is. On pad 1 on U1D1, the top trace has been rebuilt but not voltage on the VIA (circle hole). I think I have just left with the VIA but no pad What can I do? Also the trace from pin 2 going upwards has totally gone Please can someone show where alternative points are Thanks
  17. Thanks but he is not showing voltage on U1D1 pins
  18. Hi Please can someone tell me the correct voltages i should get on the U1D1 Pads please Everyone on the forums it is different. Plese help people Thanks
  19. This was booting stock fine Can someone help. Maybe its a resistor or capacitor
  20. Please can some one help me
  21. Is it possible one of the smd caps is causing this. Please can someone help Thanks
  22. @Donini II ok so how can i get it to boot retail pls
  23. @Donini II is there any chance to boot this on retail / stock firmware before i rgh pls Thanks
  24. How can i know for sure Ive not ever read the nand chip Whats the ksb chip Maybe it could be something else Please help Thanks
  25. @xbox1 Ok I measure and i get 5v on the pins on the first two pins on the right using the pic as the reference, the first two pins on the right are 5v and all the rest are 0v
