Tudo que xbox1 publicou
  1. What should the correct values be how can i get this booting
  2. @Donini II i dont have a backup and dont have another nand chip for this console are there any other tests i can do such as test resistors or something thanks
  3. @Donini II yes but i want to boot the console on stock rgh before i do anything how can i get this to boot pls pls help thanks
  4. Ok So on pad 1 (the first black arrow in the pic), I get zero volts, 000.5mv on the second pad I get 3.2v
  5. @Donini II Ok I tested voltage on the points and they are ok I get 1.2v and I get 5v
  6. I believe it has all the standby voltages but will check again Can you provide where to check the standby voltages pls.thank
  7. Is there anything else i can do to get this booting I don't think the chip is dead
  8. I have not rgh it yet Its on stock I dont have a backup of the firmware Can you confirm which is pad 2 please Thanks
  9. Hi My xbox 360 corona (4gb model) was not turning on so I replaced u5a1 with the ams117-3.3v and now the console just beeps the board needed some work doing it as a trace repair and the nand pads had gone so needed alternative points I have done all that but the console just beeps Please can anyone help please what could cause this How can I get this booting again Thanks
  10. xbox1
    em análise Xbox 360 Slim corona 4gb U5A5 and U5A4
    @sh4d0w4224 Thanks friend
  11. xbox1
    ok but can i replace with 10uf, 6.3v will this be ok I dont have another dead board to take identical ones will these work I prefer to replace them to leave blank please confirm thanks
  12. xbox1
    Hi So Can I use any uf and any voltage higher than 5v Please confirm Thanks
  13. xbox1
    Can I use 6.3V 0.1 UF or can i go higher in farad and keep same voltage or higher in voltage Thanks
  14. xbox1
    Someone must know the specs please
  15. xbox1
    what about farad how many uf
  16. xbox1
    Also does anyone know the voltage and farad to replace these pls
  17. xbox1
    i need to see under the capacitors c5a5 and c5a4 In my board the top pads are all joined as the bottom There are not separate pads I need to verify if it is correct on my board thanks
  18. I thought someone might have one Shame Thanks @willianlopes
  19. Hi Please does anyone have schematic for Xbox 360 slim corona and Trinity Thanks
  20. Hi Please Can someone upload photos of c5a5 and c5a4 I have corona 4gb board It seems like the pads and the top is all joined also the bottom is joined there are not separate pads for the two capacitors Please someone upload specs for these Thanks
  21. HI Can someone upload a pic on how to use the diodes please thanks
  22. I know it is easier and are on order for parts but taking a long time to get to me Can i use the parts from old adsl wireless routers Or is it possible to find these components from old pc power supply or ps3 bluray drive or ide hard drive pcb's do you have any links to show how to wire the diodes to the xbox360 slim corona 4gb model pls
  23. I know it is easier and are on order for parts but taking a long time to get to me Can i use the parts from old adsl wireless routers do you have any links to show how to wire the diodes to the xbox360 slim corona 4gb model pls
