varga jano
    71 [ Doar ]
Tudo que varga jano publicou
  1. Hello! Íme néhány példa a hibákra és azok kijavítására.I have an LG WD80180N washing machine which, after turning it on, prints a dE and does not close the door. I measured 78V on the wire. You probably have a panel problem. Do you have any tips for what's wrong with your window? (I once cut out a whole panel with a knife, but it's really macerious, why hurt the whole thing if a window is enough?)I advise you to open a full window next time you work. on the house! I'd do an unused solitaire in your place. Before reinserting, spray the spill area with the foil-boiling point with a light spray. I buy it on Kerekes Street. I recommend the PLASTIK-70. This can be soldered and replenishes the pouring material. I'm trying to attach photosThank you very much for the help of everyone! Looks like the cause of the problem has been found out! , which is why the foil broke in two places ... I only noticed this today. I soldered the two defective parts and the door lock and the machine start up right away! https://elektrotanya.com/content/lg-wd80180n-mosogep-de-hibakodaz-ajto-nem-zarodik#
  2. The Made in Korea washing machine has a DTC E8. A plastic window was opened on the back of the plastic molded module housing. The error was already visible. The part of the component has broken out of the solder. Suctioned tin with suction sock. Then soldered with lead containing solder tin. Washing machine repaired.
  3. "The power went out."Nutrition. IC replacement. Power .ELKO's hopesThe first photo shows that the 230Vac is fed through the foot of the heater relay (black crocodile tweezers) and the white one-way connector (red crocodile tweezers) from the DISCONNECT TRAFFIC!
  4. Nutrition. There was smoke coming from IC. "Power IC replacement. (Worth putting in.) 10uF / 450V ELKO replacement
  5. Visualizar Arquivo SMD PARTS CATALOG SMD PARTS CATALOG Uploader varga jano Enviado 21-11-2019 Categoria Datasheets
  6. varga jano
    doc SMD PARTS CATALOG
    11 downloads
    SMD PARTS CATALOG
  7. Samsung_washing_machine_modules Visualizar Arquivo Samsung washing machine modules Uploader varga jano Enviado 20-11-2019 Categoria Eletrônica
  8. Visualizar Arquivo LG_washing_machine_modules LG washing machine modules Uploader varga jano Enviado 18-11-2019 Categoria Eletrônica
  9. 8 downloads
  10. Hello! The adapter measures at two points. No need to solder for it. Easy to assemble and disassemble. I think so.
  11. washing_machine_motor_carbon_brush_replacement exploted_illustration_washing_machine_bosch_wat28401 exploted_illustration_washing_machine_electrolux_efl.zip
  12. Hi! A feltöltött LG_washing-machine_modules Janus eletronicabr.com/files/file/32803-lg_washing_machine_modules/
  13. Hello ! Please join the club! Thank you. Hi Jano eletronicabr.com/clubs/13-repair-of-large-household-appliances-white-goods/
  14. Hello ! I would like to download this file! Thank you very much in advance .
  15. Hello ! Please enable smd code book download! Thanks. Varga Jano
