Postado 17 de Maio de 2015 10 anos Achei na net uma listagem com as abreviaturas usadas em esquemas de noteboks, que acredito, irá ajudar na interpretação destes sinais no esquema elétrico. Apenas formatei o texto e disponibilizo aos colegas. No final do post, deixei um link com o arquivo PDF desta listagem para quem precisar, além do devido crédito ao autor. AC Alternating current ACDRV AC adapter to system-switch driver output ACEDET Adaptor Current Detector ACGOOD Valid adapter active-low detect logic open-drain output ACIN Adaptor Current sensor Input ACN Adapter current sense resistor ACOP Input Over-Power Protection ACOV Input Overvoltage Protection ACP Adapter current sense resistor, positive input. ADP+ Adapter Positif Suplay ADP_ID Adapter Identity AGND Analog Ground ALWP ALWAYS ON POWER B+ AC OR BAT POWER RAIL FOR POWER CIRCUIT BATT Battery BAT+ BAT POWER RAIL FOR POWER CIRCUIT BAT_DRV Bat Fet Gate Driver BAT_V Battery Voltage BOM BILL OF MATERIAL MANAGEMENT BT BUTTON BT_EN Bloototh Enable BUZER Connected BYP Baypass CHGEN Charge enable active-low logic input CIN Input Capacitor CLK_EN CLKOCK ENABLE CN CONECTOR CRT Cathode ray tube CSIN Current Sensor input Negatif CSIP Current Sensor input Positif DC Direct current DM DIM/DIM SOCKET/SOKET MEMORY/SOKET DDR DOCK DOCKING SOCKET EC Embedded Controler EC_ON Embeded Controler Enable EMI Elektromagnetik Interference(GANGGUAN ELEKTROMAGNETIK) EN ENABLE ENTRIP Enable Terminal F FUSE FSEL Frequency Select Input GATE Trigger gate GND Ground GP GROUND PIN GPI General Power Input GPIO General Power Input Output HDMI High-Definition Multimedia Interface ID Continuous Drain Current IDM Pulsed Drain Current IIN Operating Supply Current IIN(SHDN) Shutdown Supply Current IIN(STBY) Standby Supply Current IS Continuous Source Current (Diode Conduction) IVIN Battery Supply Current at VIN pin JP JUMPER POINT KBC Keyboard Controler LCDV LCD POWER LDO Linear Driver Output LGATE Lower-side MOSFET gate signal LPC Low Pin Count LVDS Low-voltage differential signaling(SYSTEM PENSIGNALAN) MBAT MAIN BATTERY NB North Bridge ODD OUTPUT DISC DRIVE PCI Peripheral Component Interconnect PGOOD Power good open-drain output PIR PRODUCT IMPROVED RECORD PSI# Current indicator input PVCC IC power positive supply RSMRST Resume Reset RTC REAL TIME CLOCK SB South Bridge SHDN Shutdown SYS_SDN System Shutdown SPI Serial Peripheral Interface TD Death Time THRM THERMAL SENSOR TMDS Transition Minimized Differential Signaling(TRANSMISI DATA TEKNOLOGY) TP TEST POINT TPAD THERMAL PAD UVLO Input Undervoltage Lock Out V RAIL(POWER) V+ Positive Voltage VADJ Output regulation voltage VALW ALWAYS ON POWER VALWP VALW PAD VBAT BATTERY POWER VCCP Power chip(ich,graphic chips) VCORE POWER PROCESOR VDD Control power supply VDDR POWER DDR (VDRAM/VRAM/VMEM) VDS VOLTAGE DRAIN SOURCE VFB Feedback inputs Power VGS VOLTAGE GATE SOURCES VIN Input Voltage Range VIN ADAPTER POWER SUPLY (vol_in) VL Power Lock VL Voltage across the load/Tegangan beban resistor VL Voltage Linear VLDOIN Power supply of the VTT and VTTREF output stage (to Power MOS) VOT Volt_Out VRAM Power Memory VREF Power Reference/Schema Reference/Tensão de referência VS SUITCH POWER VS+ SUPPORT VOLTAGE POSITIF VSB POWER SWITCH BUTTON VSS Signal ground VSW Power Switch VTT Memory Termination Voltage VTERM Memory Termination Voltage VUSB POWER USB VGA POWER VGA (VGPX/VGPU/VCVOD) VGFX POWER GRAPHIC CHIP VREF VOLTAGE REFERENCES Arquivo em PDF: Você não tem permissão para visualizar links. Faça login ou cadastre-se. Créditos:http://adiedkhazbook.blogspot.com.br/
Postado 25 de Outubro de 2018 7 anos Alguém teria uma explicação, do que seria o ENTRIP? estou com um PWM na qual a saída dele é ENTRIP3 e ENTRIP5 Abraços
Postado 25 de Outubro de 2018 7 anos Autor @Vtronic é um terminal de habilitação > ENABLE O link abaixo contém um vídeo que explica isso em detalhes e pode servir de base para outros circuitos: https://eletronicabr.com/forums/topic/51616-etapa-1-parte-1-tps51125/
Postado 23 de Novembro de 2018 7 anos Em 16/05/2015 às 22:26, Hélio disse: Achei na net uma listagem com as abreviaturas usadas em esquemas de noteboks, que acredito, irá ajudar na interpretação destes sinais no esquema elétrico. Apenas formatei o texto e disponibilizo aos colegas. No final do post, deixei um link com o arquivo PDF desta listagem para quem precisar, além do devido crédito ao autor. AC Alternating current ACDRV AC adapter to system-switch driver output ACEDET Adaptor Current Detector ACGOOD Valid adapter active-low detect logic open-drain output ACIN Adaptor Current sensor Input ACN Adapter current sense resistor ACOP Input Over-Power Protection ACOV Input Overvoltage Protection ACP Adapter current sense resistor, positive input. ADP+ Adapter Positif Suplay ADP_ID Adapter Identity AGND Analog Ground ALWP ALWAYS ON POWER B+ AC OR BAT POWER RAIL FOR POWER CIRCUIT BATT Battery BAT+ BAT POWER RAIL FOR POWER CIRCUIT BAT_DRV Bat Fet Gate Driver BAT_V Battery Voltage BOM BILL OF MATERIAL MANAGEMENT BT BUTTON BT_EN Bloototh Enable BUZER Connected BYP Baypass CHGEN Charge enable active-low logic input CIN Input Capacitor CLK_EN CLKOCK ENABLE CN CONECTOR CRT Cathode ray tube CSIN Current Sensor input Negatif CSIP Current Sensor input Positif DC Direct current DM DIM/DIM SOCKET/SOKET MEMORY/SOKET DDR DOCK DOCKING SOCKET EC Embedded Controler EC_ON Embeded Controler Enable EMI Elektromagnetik Interference(GANGGUAN ELEKTROMAGNETIK) EN ENABLE ENTRIP Enable Terminal F FUSE FSEL Frequency Select Input GATE Trigger gate GND Ground GP GROUND PIN GPI General Power Input GPIO General Power Input Output HDMI High-Definition Multimedia Interface ID Continuous Drain Current IDM Pulsed Drain Current IIN Operating Supply Current IIN(SHDN) Shutdown Supply Current IIN(STBY) Standby Supply Current IS Continuous Source Current (Diode Conduction) IVIN Battery Supply Current at VIN pin JP JUMPER POINT KBC Keyboard Controler LCDV LCD POWER LDO Linear Driver Output LGATE Lower-side MOSFET gate signal LPC Low Pin Count LVDS Low-voltage differential signaling(SYSTEM PENSIGNALAN) MBAT MAIN BATTERY NB North Bridge ODD OUTPUT DISC DRIVE PCI Peripheral Component Interconnect PGOOD Power good open-drain output PIR PRODUCT IMPROVED RECORD PSI# Current indicator input PVCC IC power positive supply RSMRST Resume Reset RTC REAL TIME CLOCK SB South Bridge SHDN Shutdown SYS_SDN System Shutdown SPI Serial Peripheral Interface TD Death Time THRM THERMAL SENSOR TMDS Transition Minimized Differential Signaling(TRANSMISI DATA TEKNOLOGY) TP TEST POINT TPAD THERMAL PAD UVLO Input Undervoltage Lock Out V RAIL(POWER) V+ Positive Voltage VADJ Output regulation voltage VALW ALWAYS ON POWER VALWP VALW PAD VBAT BATTERY POWER VCCP Power chip(ich,graphic chips) VCORE POWER PROCESOR VDD Control power supply VDDR POWER DDR (VDRAM/VRAM/VMEM) VDS VOLTAGE DRAIN SOURCE VFB Feedback inputs Power VGS VOLTAGE GATE SOURCES VIN Input Voltage Range VIN ADAPTER POWER SUPLY (vol_in) VL Power Lock VL Voltage across the load/Tegangan beban resistor VL Voltage Linear VLDOIN Power supply of the VTT and VTTREF output stage (to Power MOS) VOT Volt_Out VRAM Power Memory VREF Power Reference/Schema Reference/Tensão de referência VS SUITCH POWER VS+ SUPPORT VOLTAGE POSITIF VSB POWER SWITCH BUTTON VSS Signal ground VSW Power Switch VTT Memory Termination Voltage VTERM Memory Termination Voltage VUSB POWER USB VGA POWER VGA (VGPX/VGPU/VCVOD) VGFX POWER GRAPHIC CHIP VREF VOLTAGE REFERENCES Arquivo em PDF: https://eletronicabr.com/forums/topic/49309-siglas-usadas-em-esquemas-elétricos Créditos:http://adiedkhazbook.blogspot.com.br/ tabela muito boa de se trabalhar é muito inportante essas siglas vai facilitar muito o meu trabalho....
