    21 [ Doar ]
Tudo que scobie publicou
  1. No sorry I think you are referring to a different board. These do not exist on this board can you say which component numbers they are like Uxxx PQxxx
  2. I have i3 la-6842p that powers itself down rapidly even in bios after less than 1 minute. I have swapped Cpu/Ram fitted new thermal paste changed power supply/bench supply but still the same. Where is the best place to start?. Many thanks.
  3. Hi the only marking on the motherboard is K54c Rev2.1 then a label saying 11591674mb0184 Also found n9tmb1100-b24 on ram slot (11578169) 69N0mdm11b24 and under ram slot is 10bf48233a4d
  4. Hi Im looking for a schematic for ASUS x54c if anybody has one. Many thanks
  5. Hi anybody have experience with this model Toshiba C660 motherboard LA-6842p. Laptop posts then less than 1 minute fan runs fast then shuts down suddenly. I have tried swapping heatsink/cpu/ram but still the same. the most current drawn is 1A. everything is stripped inc wireless card from motherboard. These are what I have so far PJ1=3.3v PJ4 =1.5v PJ5=5.18v PJ11/13=1.04v PJ3=1.78v PJ9=3.3v PJ8/10=1.05v None of these fluctuate greatly or change just before shut down. Many thanks
  6. Many thanks I will try that.
  7. Hi would anybody have a bios file for a Toshiba C50D-A_10M (PSCHNE) I downloaded one and it wont fit on the 4mb chip using external programmer.
  8. Does anybody know how to modify bios size?
  9. I reflashed my original bios file and now laptop works again. I mentioned it too soon. Laptop will not show video output again. Im going too change Bios chip to see what happens.
  10. Hi under the label is printed tmt YA-4A 19 E114139 94v-0 1334 Then beside it not under the sticker is PT10ABX(PT10ABX/PT10ABGX) Main Board Rev:2.1 I know its very unusual because I cannot find anything on the web Thers one more sticker that has the following 12531354-01230-69N0CKM308(or the 8 could be B, its hard to tell)02-01.
  11. Apologies I was not thinking, try this link http://www.4shared.com/rar/MJCzjwnAba/c50_bios.html#
  12. How to post bios ?, system wont allow me only .jpg .png ect?
  13. No the header is different also laptop wont switch on now. If I put original file on the laptop switches on by itself even without power button attached so Im suspecting BIOS or KBC. Also original problem stillpersists as in no video external or Led screen Black (no video output)
  14. Hi I have a unit that switches on by itself but no video output all voltages seem to be present on the coils. I was attempting to flash the bios but the one I downloaded from the Toshiba website when extracted my programmer says its too big for the chip. There only seems to be 1 eeprom on the board that I can see. The unit has AMD BGA Cpu onboard. Any assistance wold be greatly appreciated
  15. Thank you but no this is different to mine this uses a Wistron KBC but mine uses a Nuvoton, also cpu n mine is bga not socketed.
  16. No I cannot see any other numbers I have searched over the board. the only other number is E114139 E114139 PLF/PLR/CSF/CSR ?? All details are tmt YA-4A 19 E114139 94v-0 1334 Then PT10ABX(PT10ABX/PT10ABXG) REV:2.1 Thn beside ram slot, PT1253135401230 PT10ABX 12531354
  17. No I cannot see any other numbers I have searched over the board. the only other number is E114139
  18. Hi Im looking for a schematic for this laptop please. Toshiba C50d PT10ABX/PT10ABXG REV:2.1 schematic needed please. AMD CPU
  19. Hi Would anybody have schematic for Samsung R530 ba92-06379b please, marked on the board is BA41-01219A Bremen-C (100210)-4 REV:1.1 Many thanks
  20. You should have your 3.3v alws volatge on both your poweerbutton and at various pins on the Sio/KBC. Find out which pin on the Sio is the kbc_pwrbtn this voltage should go to 0v when the powerbutton is pressed and this should start thing off. Mesmo sem as tensões de 3.3 e 5v esses sinais aparecem no I/O? acredito que não né...abraço
  21. Again apologies as a newbie but thank you all for your help.
  22. Hi Im trying to locate schematic for Packard Bell TE11HC Q5WVH LA-7912p rev1.0 please I already have .2 and .3 but I need rev:1 and also boardview if available
  23. Greetings my name is Scobie. I live in Ireland. Interested in Laptop motherboard repair/Robotics
