    10 [ Doar ]
Tudo que S M publicou
  1. S M
    dúvida PS3 Fat serie hh12 com ylod
    you can replace each NEC/TOKIN capacitor with 3 or 4 tantalum capacitors (usually 330μF 2.5V or 470μF 2.5V), but you must be very careful with the installation: Do not use jumpers — jumpers can cause shorts or unstable behavior, especially on the CPU side. Instead, solder the tantalum capacitors directly to the pads where the NEC/TOKIN was located. Make sure they are connected in parallel and properly aligned. Keep your wiring short and clean. Use thin wires if needed, but avoid long connections. Always test with a multimeter for shorts before powering on.
  2. It sounds like your console is stuck in a glitch loop — the Matrix V3 chip is trying to glitch the console every 4 seconds but fails to boot. Here are a few things you can try: Double-check wiring: Make sure all your solder points are clean and correctly placed, especially point A and the CPU_RST line. Revert capacitor change: Try putting back the original 0.212pF capacitor if you still have it. 0.01uF might be too strong and affect the timing. Timing files: If you're using a NAND with specific timing files, they might not match your console’s CPU type. Try a different timing file or profile. Try another chip or board: If possible, test with another glitch chip or test your Matrix V3 on another board to rule out a faulty chip. Post NAND details: If you can, share your NAND info (CB version, motherboard model, etc.) to better understand the setup.
  3. S M
    apresentação Hi, I'm SM / UK
    Thank you, I look forward to learning and helping other users where possible. Do you know which forum would be best to look at for console modding?
  4. S M
    Hi, I'm SM / UK
    Thank you! I'll check them out - much appreciated!
  5. S M
    I am an owner of a gaming community and saw this forum as a nice community to get involved with. I am 29 years old and from UK. I look forward to talking with you all!
