Xbox 360 Slim corona, 4gb model just beeps
Hi
My xbox 360 corona (4gb model) was not turning on so I replaced u5a1 with the ams117-3.3v and now the console just beeps
the board needed some work doing it as a trace repair and the nand pads had gone so needed alternative points
I have done all that but the console just beeps
Please can anyone help please
what could cause this
How can I get this booting again
Thanks
  • Respostas 59
  • Visualizações 19,2k
  • Criado
  • Última resposta
Principais posts deste tópico
Most Popular Posts
Imagens Postadas
@xbox1tenta fazer a leitura da nand, se não conseguir verifica a tensão no pad 2, caso esteja com 1,7v é quase certo que terá que trocar o ci da nand, ou converter para v3.
(try to read the nand, if you can not check the voltage in pad 2, if you are 1.7v, you almost have to change the ci of the nand, or convert to v3.)
Editado: por Donini II
I have not rgh it yet
Its on stock
I dont have a backup of the firmware
Can you confirm which is pad 2 please
Thanks
Is there anything else i can do to get this booting
I don't think the chip is dead
esqueci de pedir se tem as tensões de standby, 5v, 3,3v e 1,2v.
(I forgot to ask if it has the standby voltages, 5v, 3.3v and 1.2v)
3 minutos atrás, xbox1 disse:
os pads que pedi para você medir é para saber se tem defeito no ci da nand.
(the pads I asked you to measure is to know if you have a defect in the ci of the nand.)
I believe it has all the standby voltages but will check again
Can you provide where to check the standby voltages pls.thank
@Donini II
12 hours ago, Donini II said:
Ok I tested voltage on the points and they are ok
I get 1.2v and I get 5v
15 hours ago, Donini II said:
Read pad one and two.
(Read pad one and two.)
pads nand corona v4 -. jpg
Ok So on pad 1 (the first black arrow in the pic), I get zero volts,
000.5mv
on the second pad I get 3.2v
como as tensões estão todas corretas, vai ter que fazer a leitura da nand.
(as the voltages are all correct, you will have to read the nand.)
@xbox1
@Donini II
(as the voltages are all correct, you will have read the nand.)
@xbox1
yes but i want to boot the console on stock rgh before i do anything
how can i get this to boot pls
pls help
thanks
@xbox1a leitura da nand é para saber se o ci esta bom, se fizer leitura correta descartamos defeito no ci, e já terá um backup da nand do seu xbox, caso não faça leitura terá que trocar o ci da nand e só funcionará com rgh, a não ser que tenha um backup da nand original.
(the reading of the nand is to know if the ci is good, if you read correctly we discard defect in the ci, and already have a backup of the nand of your xbox, if you do not read it will have to change the ci of the nand and will only work with rgh, unless you have a backup of the original nand.)
@Donini II
i dont have a backup and dont have another nand chip for this console
are there any other tests i can do such as test resistors or something
thanks
@xbox1
conecte a fonte de energia e verifique a tensão nos pads do ci U1B1.
(connect the power supply and check the voltage on the U1B1 ci pads.)
39 minutes ago, Donini said:
@xbox1
What should the correct values be
how can i get this booting
Editado: por xbox1
20 hours ago, Donini II said:
@xbox1
@xbox1
Ok I measure and i get 5v on the pins on the first two pins on the right
using the pic as the reference, the first two pins on the right are 5v and all the rest are 0v
@xbox1
isso indica que, ou o software da nand esta corrompido, ci nand com defeito ou chip KSB com defeito.
(this indicates that either the nand's software is corrupted, the defective ci nand or the defective KSB chip.)
How can i know for sure
Ive not ever read the nand chip
Whats the ksb chip
Maybe it could be something else
Please help
Thanks
@xbox1vai ter que tentar ler a nand, faça um adaptador caseiro ou compre um.
 Segue imagem do esquema do adaptador sd.
(will have to try to read the nand, make a homemade adapter or buy one.
  Here is the schematic image of the sd adapter)
@Donini II is there any chance to boot this on retail / stock firmware before i rgh pls
Thanks
1 hora atrás, xbox1 disse:
Thanks
only, if you can read the nand.
