o__rionTG
1.2 -
4.047 -
Vitórias
13 -
194 [ Doar ]
Tudo que o__rionTG publicou
 em análise SmartPhone Samsung Gran Prime - [ G530H ] - Qualcomm SecureBoot Enable + Secure Download Enable
o__rionTG respondeu o tópico de o__rionTG em Celulares, Smartfones e Câmeras fotográficas
@ticojds Não tenho , se puder UP no fórum e me envie o link. -
@ticojds Apos esse reparo o Windows Reconheceu como Qualcomm HS-USB QDLoader 9008. Vou tentar refazer o reparo, caso não funcione acho que só com a troca da Emmc. -
@ticojds Conectei na Medusa Pro e estou tendo a leitura da Emmc, porém ao grava diz que está protegida ou danificada. SW: 1.6.2; FW: 1.24. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G530H_EMMC_P1J95K.srf". Write data verification is enabled. Writing GPT partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G530H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G530H_EMMC_P1J95K.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QNW00M Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100514E5730304D009A59C8E391BF Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QNW00M Product revision : 0.0 Product serial number : (hex) 9A59C8E3 Manufacturing date : 09/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 376832 Number of sectors : 3063808 Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QNW00M_17_08_2018_18_16_07.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.2; FW: 1.24. -
@ticojds Vou realizar o procedimento de Emmc via Medusa Pro, irei fazer um limpa nessas partições e regravar novamente com o arquivo SRF. Vamos ver o que vai dar -
@o__rionTG Passei a versão Russa aqui, o aparelho completou o reparo, mas ao liga-lo ele cai na tela de RECOVERY e mesmo mando dar Reboot System Now ele volta para mesma tela. Advanced mode! Firmware write started. Escrevendo a secção ABOOT... Writing firmware Canceled Performed by 2.7.0.3 Software version. Selected BOOT file: C:\Users\Megatron Eletronica\Desktop\drive-download-20180817T193848Z-001\BL_G530HVJU2AOE1_CL576251_QB4944794_REV00_user_low_ship_MULTI_CERT.tar.md5 Selected AP file: C:\Users\Megatron Eletronica\Desktop\drive-download-20180817T193848Z-001\AP_G530HVJU2AOE1_CL576251_QB4944794_REV00_user_low_ship_MULTI_CERT.tar.md5 Selected CP file: C:\Users\Megatron Eletronica\Desktop\drive-download-20180817T193848Z-001\CP_G530HXXU2AOD1_CL539949_QB4798199_REV00_user_low_ship_MULTI_CERT.tar.md5 Selected CSC file: C:\Users\Megatron Eletronica\Desktop\drive-download-20180817T193848Z-001\CSC_ZTM_G530HZTM2AOE1_CL576251_QB4944794_REV00_user_low_ship_MULTI_CERT.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G530H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Escrevendo a secção ABOOT... A secção ABOOT foi escrita com êxito Escrevendo a secção SBL1... A secção SBL1 foi escrita com êxito Escrevendo a secção RPM... A secção RPM foi escrita com êxito Escrevendo a secção QSEE... A secção QSEE foi escrita com êxito Escrevendo a secção QHEE... A secção QHEE foi escrita com êxito Escrevendo a secção APNHLOS... A secção APNHLOS foi escrita com êxito Escrevendo a secção sec... A secção sec foi escrita com êxito Escrevendo a secção BOOT... A secção BOOT foi escrita com êxito Escrevendo a secção RECOVERY... A secção RECOVERY foi escrita com êxito Escrevendo a secção SYSTEM... A secção SYSTEM foi escrita com êxito Escrevendo a secção PERSIST... A secção PERSIST foi escrita com êxito Escrevendo a secção PERSDATA... A secção PERSDATA foi escrita com êxito Escrevendo a secção MODEM... A secção MODEM foi escrita com êxito Escrevendo a secção CACHE... A secção CACHE foi escrita com êxito Escrevendo a secção HIDDEN... A secção HIDDEN foi escrita com êxito A escritura do firmware foi completada com êxito Performed by 2.7.0.3 Software version. -
 devolvido Smartphone Motorola Moto G4 Play - [ XT1603 ] Erro ao buscar redes.
@ticojds Sim Sim, na correria acabei esquecendo de finalizar, eu editei o tópico logo após sua mensagem. -
@ticojds Perdão amigo, Tópico está como NÃO RESOLVIDO. Devolvi o aparelho. -
@ticojds Praticamente estou com esse aparelho a 1 semana, por média ficam entre 2 horas. As que permanecem na logo eu não tenho acesso ao modo recovery, somente Download. Já nas demais quando passam elas já caem no modo Recovery e mesmo fazendo Wipe Data elas sempre voltam para mesma tela. E olha que eu tentei várias Stock Rom... Nesse momento estou tentando uma da Russia. -
 em análise Smartphone Samsung Grand Prime - [ SM-G530BT ] - Falha na Instalação da Rom
o__rionTG respondeu o tópico de Luiz Eduardo Luchi em Celulares, Smartfones e Câmeras fotográficas
@Luiz Eduardo Luchi Qual o andamento dessa manutenção ? -
o__rionTG postou um tópico em Celulares, Smartfones e Câmeras fotográficas
Estou com um aparelho da Samsung de modelo citado acima, ondem estou tendo dificuldades para recuperar. Tentei instalar várias Stock Rom pelo Odin e Octoplus porém o mesmo não consegue inicializar, dependendo da Stock Rom instalada eu tenho o acesso ao modo Recovery, dependendo de outras não tenho acesso. Há algumas Stock Rom que deixam o aparelho travado na logomarca, porém os drivers são todos instalados e reconhecidos. Gostaria de uma segunda opinião dos colegas se consigo resolver sem telo que abrir e fazer reparo direto na Emmc com a MEDUSA. -
 em análise Smartphone Samsung Galaxy S3 - [ GT-I9300 ] - Não Inicia completamente
o__rionTG respondeu o tópico de cristianjasco em Celulares, Smartfones e Câmeras fotográficas
@cristianjasco Veja qual Driver é reconhecido no Gerenciador de Dispositivo do Windows, verifica se ele entra em Modo Download ou Recovery -
 resolvido Zenfone 2 modelo ze550kl sem sinal de operadora
o__rionTG respondeu o tópico de geekinfostudios em Casos Resolvidos - Celulares, Smartfones
@ticojds hehehehe, é verdade, ambos os fio estão no aterramento.... Nem eu tinha percebido. -
@geekinfostudios Não inverteu os fios ? -
 resolvido Motorola G4 - XT1626 - Loop Infinito - OS 4737
o__rionTG respondeu o tópico de mobilehouseinfo em Casos Resolvidos - Celulares, Smartfones
@mobilehouseinfo Verdade, teria o botão power a ser verificado. Mas mesmo assim parabéns pela manutenção -
@mobilehouseinfo Quando manda escrever o Software ele passa normal sem erros , Outra coisa qual o problema relatado pelo cliente e qual driver está sendo reconhecido no gerenciador de dispositivo ? -
@mobilehouseinfo Faça um teste com uma outra bateria. -
 resolvido Asus Zenfone GO - [ ZB500KL ] - Qualcomm-HS-USB QDloader 9008
o__rionTG respondeu o tópico de lecarvalhofranca em Casos Resolvidos - Celulares, Smartfones
@lecarvalhofranca Legal amigo, parabéns pela manutenção. -
 em análise Smartphone Motorola Moto G5S Plus - [ XT1802 ] - Não Carrega.
o__rionTG respondeu o tópico de W.SOUZA! em Celulares, Smartfones e Câmeras fotográficas
@W.SOUZA! O LED de indicação de charge fica aceso ? No Conector de Bateria deve existir uma tensão próxima de 4.20V, efetue a troca do conector de carga para ver se o problema não é nele, também verifique se existe a tensão de +5V no pino do conector de carga. Faça uma análise nos componentes próximos ao conector e nos setores das imagens abaixo. -
@W.SOUZA! Qual o modelo técnico desse aparelho ? -
 dúvida Tablet DL, mostra carregando, mas não carrega bateria
o__rionTG respondeu o tópico de Diego Wodanaz em Tablet, Ipad
@Diego Wodanaz Verifica se não tem um componente chamado APX , ele é um IC de gerenciamento de carga, é comum esse componente apresentar falha. Qualquer coisa posta uma foto bem nítida da sua placa aqui.- 4 respostas
@geekinfostudios Olá amigo, consegue uma foto do local onde estava avariado ? -
@Chico. Antônio Posta a imagem dos erros que o Odin te mostra, outra coisa você está usando a ROM de 4 partes + PIT ? @Chico. Antônio Siga a Orientação acima, e fique atento as regras do fórum.
 dúvida Frontal do Zenfone 2 ZE551ML após instalado a tela funciona mas touch não funciona.
o__rionTG respondeu o tópico de HenriqueSLS em Celulares, Smartfones e Câmeras fotográficas
@HenriqueSLS Que bom que resolveu, Fique atento nas próximas troca as vezes um minimo detalhe faz toda diferença. -
 em análise Câmera Digital Fuji finepix - [ S4080 ] Fica na tela pedindo pra desligar e ligar
o__rionTG respondeu o tópico de android121234 em Celulares, Smartfones e Câmeras fotográficas
@android121234 o Foco da câmera chega a sair ou abrir ?
