alexcefet
    302 [ Doar ]
Tudo que alexcefet publicou
  1. tenhos estes cofigospara te fornecer Amigo . FREE Ink Reset Codes for Epson L100, L200, L800 - enjoy! When your Epson L100, l200 or L800 printer gives the message like "Ink Out. Replace Inks" You have to buy expensive Epson ink bottles with Ink Codes on them. Epson Ink Out error But You can now use our FREE Ink Codes and refill Your printers with inks you like. Not need to pay more money for Epson Ink Bottles! Ink Reset Codes (Reset ID) for Epson L100 and L200 4 colors printers Ink reset id codes free for Epson L100, L200, L800 Cartucho Preto : EKA-3TF-A24-GETR J3K-958-9J4-5DLN GDU-T62-G5N-3GMJ 7UR-BVW-47F-MBLZ GPC-XJQ-VT9-799R 6T2-YBZ-9WX-J42A 3BV-YV9-459-S2RC 2YB-CXS-T8D-KXDG 445 - 645 - 6UD - E7VQ X52 - 4HD - UVR - ZYRC YVJ - FAW - J92 - QUES VYM - 8WZ - 5F2 - RMQ3 B3M - QUH - 5ZB - YE8Z TW7 - 6UE - BN4 - L8MB 63C - 8CD - DDQ - 55DA A6X - 4HV - DQ9 - X3BZ 38J - 7W3 - 7WF - AL2B H7R - HJK - FFU - P6EM VB5 - 3TW - TVE - 9PAP JW6 - W7J - D3S - JFGE Y56 - DUY - NVN - 9425 RC9 - NKD - RVP - 29Q3 CK8 - JPG - HCX - MKRY Cartucho Azul : XXX-996-B96-BBUC DV9-E8U-JW4-K47Z WQ3-8ZR-M6Z-Z96F MAY-M8D-8LZ-VUXC VKP-V8T-87L-PGWB LHL-K58-D3H-GV25 vbm - L3q - 4wp - v2te Y2A - VBR - QBZ - XD3Q H2X - 4UX - 7X9 - 4KCP B84 - RUA - MM7 - UY85 JSL - 5PU - 5HL - QQBF CL4 - CQB - HUG - Y53P A92 - Y6J - YTM - 55VZ DY5 - 744 - DTS - CR4A J44 - 5LP - 2QL - WCWP B94 - MK2 - UXJ - 2BGE 4ND - YSC - M3G - VGNC NCW - 9EA - GCM - 7XMN UQG - BCE - 7VQ - YGZY Cartucho Vermelho : LV5-BJ8-W26-GSJS SYH-LYR-7RR-L8EF MWA-MUJ-W6K-YJDY HXB-ES6-5TD-UKRP BJ2-HB4-8QP-GKPQ 4XP-YJ7-N7Z-6X63 VKT - 3N8 - K3S - EDQR LDR - 2EA - 6KL - 4KCP K5X - AW3 - VDU - X8GN FEA - 8Q8 - UZM - B7U5 FXL - LFM - XAY - LUR3 9A2 - E8J - BH9 - 8D6Z F7B - 339 -ED2 - J4UA X4H - PNM - 2V5 - DGNZ 22L - AML - DVU - 9RK9 72W - J3K - 4BE - L7KG EG2 - JSH - 6HY - KBX5 CEA - 393 - CPQ - 2URE Y9M - T7N - W4B - H9UM Cartucho Amarelo : RXU-7VR-XK7-P7JZ FX2-6XP-PGL-LTFP K33-RG2-YRN-XACJ QGM-5Z8-6UC-UWBQ B5W-AZ8-F82-QADY G4A-9VQ-A8Q-2EFZ DN4 - 5BE - S26 - NMY5 ALQ - W9G - 92W - YDMN PPZ - FTN - 6TL - D8EZ QDB - L3C - 5NU - TP5G VPT - 36F - A3E - KW7E QGD - P7Q - PLX - CNUZ 7XG - B4Q - QFZ - XCJG HM9 - JVZ - LQ3 -H4BA 5G3 - VR3 - HPU - 6XDZ 77X - 5CP - 527 - H4JZ ADE - BRE - Z8S - JR6J 34R - 6Y3 - PBK - E8BG 62L - 9E4 - L76 - RHYG
  2. Acho que voce esta com um conversor paralelo para usb ou seja um lado paralelo e outro usb , instalar normalmente depois no driver da impressora achar portas depois marcar pool de impressão marcar a LPT1 e Tambem Marcar a Porta USB . Para funcionar corretamente tem que fazer isto
  3. estarei os fazendo nodomingo que fico tranquilo
  4. Não tem Ponto não , na verdade e so colocar e funcionar . tem como tirar uma foto dela ai se for o caso tenho desta máquina aqui inteira que queimou a placa logica consigo te passar a engrenagem
  5. TENHO MANUAIS DE NO-BREAK VARIOS GOSTARIA QUE OS AMIGOS ME EXPLICA-SE COMO POSTO AQUI PARA TODOS TER ACESSO
  6. Gostaria de saber se capacitores de partida podem ser feito associação , pois sei que capacitores comum podem
  7. So uma dica ja aconteceu muito do monitor do cliente ter 2 entradas a digital e a analogica , quando ele esta em digital e o monitor não esta em automatico para mudar para analogico quando pluga o cabo ele desliga mesmo a digital e dvi e a anagolica e a vga . Não sei se e isto não no seu caso só estou dando uma dica
  8. tambem ja peguei muitas com pedaço de Papel agarrado no trasionador do papel atras ou perto do pick roller ou ate algo preso no separador de folhas . uma dica para varios tipos de impressoras tenha sempre na sua bancada um pvc ou aquele material plastico que fica dentro da tela de LCD para passar na impressora para ver se não tem papel agarrado pois a casos que assim eu ne chego a desmontar a máquina
  9. teve uma impressora desta que resolvi trocando somente o ci de 6 pinos . ele e um ci codigo CM1231 seu Datasheet esta http://www.onsemi.com/pub/Collateral/CM1231%20DATA%20SHEET.PDF não me apareceu nenhuma com este defeito depois desta data mais pela pinagem tentem ai e me de uma resposta jumpear pino 1 compino 3 , jumpear pino 4 com pino 6 . me parece que ele e somente um protetor de usb pino 1 ele é o A out e pino 3 A in Pino 4 B in e pino 6 B out Não garanto que vai dar certo não é uma tentativa quem fizer na placa ruim não vai ter problema pois a placa já esta ruim mesmo
  10. Realmente placa logica pelo jeito regravar a bios para ver se da certo
  11. Esta impressora estava dando esta mensagem erro de sistema chame o suporte . Ao Ligar a maquina no cliente verifiquei que o kit de limpeza não estava atuando . Pequei a maquina no cliente e quando abri a tampa lateral movimente o kit de limpeza com a mão rodando a engrenagem vi um papel embuchado no kit de limpeza . retirei e o problema foi resolvido .
  12. Voces podem ate não acreditar mais ja peguei um aparelho com tela branca que o fusivel estava com medida no multiteste mais dava tela branca tirei ele e coloquei um fio e funcionou , Eu não acredito mais na medida deste fusivel
  13. Amigo não confia no capacimento não troca eles , outra coisa este e led ou LCD , a fonte dele e interna ou externa
  14. São as Impressoras mais antigas mais a montagem voce não gasta nada por poder pegar os componentes na sucata e custo 0 de chip , testado o projeto http://www.thiagomedeiros.com/site/utilitarios/esquema-p-resetar-chip-samsung-scx-4200
  15. INCLUSIVE QUEM ME PASSOU E AUTORIZADO SMS FIZ CURSO COM ELE EM SP NA AREA DE MONITORES LCD , TODOS APARELHOS QUE FIZ NENHUM VOLTOU LEIAM O SUbstituto do LM19CIZ sensor de temperatura no-breaks SMS Na placa tem G S E , então o sequinte peque um diodo 1N4148 e ligue a um resistor de 1 k sendo que voce tem que ligar na parte do anodo deste diodo a este resistor , depois disto ficou 1 terminal do diodo lado catodo e um terminal do resistor de 1 k , o lado do resistor que sobrou voce conecta em E , o lado do diodo que sobrou vc liga em S , e por ultimo coloque um resistor de 220 ohms entre G e S . Ta pronto seu novo LM 19 CIZ com 3 componentes discretos .
