devolvido HD Hitachi- HTS543225L9A300- Com senha
Olá amigos estou com este HITCHI 250GB - modelo HTS543255L9A300 está com uma senha já tentei retirar e não estou conseguindo existe algum modo de atualizar a firmware e recuperar este HD?  ele reconhece nas bios dos notebooks e leitores satas
Editado: por Rodriguez
, HDD Unlock Wizard is a user-friendly application which allows you to easily remove HDD password. IDE and SATA hard disk drives are supported. Both User and Master password can be removed.
While unlocking, HDD Unlock Wizard will erase and re-certify the drive.
If you need unlocking which is safe to your data, please use A-FF Repair Station
HDD Unlock Wizard supports:
Unlocking of desktop drives
Unlocking of X-BOX drives
Unlocking of 2.5-inch laptop drives
List of supported drives
Diagnose your locked hard disk drive for free!
Download HDD Unlock Wizard for Windows 2000/XP
Unlocking of a 80GB HDD takes approximately 25 minutes. 2.5 inch notebook drives need slightly more time.
WHAT IS HDD PASSWORD?
All hard disk drives have the possibility to set a hardware password, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. When you set a password on your notebook, the drive becomes locked as well. XBox gaming consoles and some desktop computers can also lock hard disk drives. This is usually called "HDD password" or "ATA password".
If you forget the original HDD password, there is no way of restoring it by generic system tools. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow to remove an unknown HDD password and make hard drive usable again.
Achei isso, da uma olhada.
nenhum dos dois modos funcionou, alguém tem alguma ideia.
Obs: este note é de um Dell Importado foi habilitado a opção de roubo sem querer e bloqueou o HD.
Cliente não tem mais a nota fiscal para fazer o reset, e o pessoal do suporte técnico da dell querem 800,00  pra resetar :'(
, todos os métodos que já tentei também não dão certo a não ser os próprios do fabricante. Acredito que não tenha o que fazer.
, um colega do fórum está anunciando isso, de uma olhada
conseguiu resolve o problema??
vou ver se encontro a master-senha dessa serie do seu HD.
mais veja esse vídeo talvez possa lhe ajuda em alguma coisa:
ja viu esse tópico:
posso ser que lhe ajude.
Você pode usar programas pra quebra a senha Como o "HDD Password" Este programa só funciona em sistemas Windows 32 bits. Se você usa um sistema de 64 bits tente usar uma máquina virtual com um sistema Windows x86. Tem ambém o HDD Unlock é uma aplicação com interface amigável e serve para remover facilmente as senhas de disco rígido IDE ou SATA.
Normalmente este programa é usado na remoção de dados criptografados por BitLocker e semelhantes. Mas em alguns casos foi possível remover as senhas de boot do HD.
Nando, você tem o "Hiren´s Boot CD" ou o "Ultimate Boot CD"?
Lá tem um programa chamado "MHDD".
1. Dê o boot pelo Hiren's ou Ultimate
2. No menu principal selecione “HDD” > “Diagnostic” > “MHDD v4.6”
3. Você verá uma lista dos discos, selecione o disco que deseja desbloquear
4. Digite “unlock” e responda “1” para "master password"
5. Entre a senha master (master password). Se estiver errada, o menu "ERR" irá ficar vermelho, no topo da tela, e você terá mais 4 tentativas antes do disco desligar)
6. Se ele aceitar, digite “DISPWD” e responda “1”. (Terá um aviso se o disco ainda estiver bloqueado)
7. Redigite a senha master novamente para desbloquear o disco (o menu "ERR" ficará vermelho se estiver errada)
8. Digite "exit" e “ctrl + alt+ del” para reiniciar.
Veja se funciona.
Um abraço.
Nando, se ainda assim não der certo eu tentaria uma outra abordagem, eu nunca tentei, mas pode funcionar, ou no mínimo seria interessante como discussão e aprendizado.
Parece que a senha e outras informações essenciais de um HD são armazenadas em uma área chamada HPA ou "High Protected Area" (Área de Alta Proteção), esta área não pode ser acessada e nem apagada normalmente, nem mesmo formatando, você precisa de um programa especial para isso.
Depois de acessada você geraria um arquivo com o seu conteúdo que precisaria ser aberto em um leitor de Hexadecimal, teoricamente a "password" está lá em algum lugar.
Eu tenho um programa que lê HPA.
  • 4 semanas depois...
  • 7 meses depois...
Em 13/09/2016 às 13:35, NandoZimba disse:
vou testar depois e posto o resultado
não é a senha, não existe tal senha, é um firmware alterado que procura determinado hardware para liberar o conteudo, só vai conseguir alterar se alterar o firmware.
 Li que se conectar ao aparelho de origem , vc liga o aparelho, depois do boot, tira o cabo sata, sem desligar o aparelho e connecta no pc, ai consegue formatar o HD, mas não testei.
