Debug Card
How do you use the post card in today and how would you test the Motherboard with the code appearing on it? I will tell about
Firstly, post cards are placed on the motherboard's PCI slot. Now power the motherboard and do it on the on. Firstly, on the post card, you have to check the status of all the LED lights in the following ways. Not all of the volts and signals are coming right.
How To Check Motherboard Using Diagnostic Card Easy Manual in Hindi
Debug Card INDICATORS
If CLK is the LED on, this means Clock Signal is coming to the board. Clock circuit is not working if or if it is off. This signal will come even if the CPU Socket is not processed. When the BIOS reads the processor BIOS, it remains lead-on if the light does not burn even on the motherboard, then the motherboard, RAM or processor may be defective in the motherboard. This is an onboard IRDY device when you get a ready signal. FRAME PCI Bus Frame Under normal circumstances this light should be on. It has detected a PCI frame signal. RST Reset This light just overlaps the motherboard as long as it remains on for half-a-second seconds and then it is off. If it continues to remain on, the reset signal is not correct or it will not come at all. Used to be. 12V Power Supply, on the basis of this LED, it shows that the board is getting 12v supply. If 12v is not being supplied, then it remains off. -12V Power Supply, when this LED is on, it shows that the board is getting a supply of -12V. If the -12v is not being supplied, then it remains closed. 5 V Power Supply, when this LED is on the oven, it shows that the board is getting supply of 5V. If 5v is not being supplied, then it is off.-5 V Power Supply, when this LED is on, it shows that the board is getting supply of -5v. If the -5v is not being supplied then it is off.33 V3 3.34 power supply in PCI slots of some motherboards. This is an indicator of 3.3V supply in LED motherboard. If all the LED lights are in the correct position then they will see the post code coming on the card display.
Post codes can vary in different motherboards. Because it is not necessary that everyone has the same bios of the same company as the post error code is programmed in the bio. Therefore, according to various bios the error code or post code may be different. Here is the main error code coming out here.
Award BIOS
Error code: 00 (FF)
Code Meaning → If this code comes then Post Self Test is not going to be correct in the motherboard.
Solution → When the code comes, the motherboard either processor is bad or the processor is not getting the right supply. For this, replace the CPU again or the second. And check the core vault to be correct. If everything is okay then the bios may be bad, programmers can re-bios.
Error Code: 01
Code meaning: This code means that there is a problem during the Processor Test.
Solution → If the code stops on this code then check all the components related to the processor. Such as FSB on processor voltage, frequency, CPU overlapping. Reset bios by jumper. If everything is fine then the processor is bad, change it.
Error code: C1 to C5
Code meaning: When this code comes, there is a problem related to memory self-test.
Solution → This code comes when the RAM does not work correctly. Most codes are stopped at this code when the signal is not received correctly. For this, clean the RAM pins and RAM slots and clean the RAM again. (Clean the pins of the RAM with the rubber wiping) or change the RAM to the other. Occasionally this problem occurs even when bios is bad.
Error code: 0D
Code Meaning: This code comes when the video channel does not pass the testing.
solution → Add or change graphics card when this code comes.
