  2. @Dionildo Para seu caso recomendo abrir então um tópico para que receba ajuda específica para você.
  3. neste link tem uma compatível com o modelo descrito acima https://shopee.com.br/verify/traffic?anti_bot_tracking_id=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&app_key=mfreyJidXNpbmVzcyI6IlBEUCIsIm1mciI6IjAiLCJtZnJfY2FwdGNoYSI6IiJ9.PC&client_id=&is_initial=true&next=https%3A%2F%2Fshopee.com.br%2FMembrana-Microondas-Compativel-Carrefour-Hmo20e-21.14.00-i.1126182992.23797308777&redirect_type=2&scene=crawler_item&should_replace_history=true e aqui a descrição dela PRODUTO: MEMBRANA MICROONDAS CARREFOUR HMO20E 21.14.004 N° DA PEÇA: 21.14.004 MARCA COMPATIVEL: Carrefour MODELO DE MICROONDAS COMPATIVEL: HMO20E este é o modelo da membrana ok. Se for procurar pelo modelo do microondas não vai achar mesmo, procure pelo modelo da membrana tem até no mercado livre e mais barato. kk Boa Sorte
  4. se ele não liga nada, verifique o circuito de entrada, nele pode haver um diodo ou capacitor em curto o que não deixa ele ligar e junto ao botão tem um fusível smd, olha ele também, geralmente ele pifa quando se já uma chupeta de bateria sem colocar o cabo negativo à carcaça do veículo e o positivo no polo da bateria, sorte só ter queimado o radio, pois em algumas situações leva os módulos eletrônicos do veículo. Boa Sorte
  6. Bem, este problema de saturar pode ser devido a problemas no relé ,mas como comentou estão todos bons, e também na bateria? algum ponto de solda fria nesta placa? e os IRF's verificou também??
  7. olá, estou com uma igual a sua, poderia me informar certinho como vc fez esse processo?
  8. Arquivo .bin Chromebook Multilaser M11c-pc914 Garg meu nome é Dennis sou Teresina Piauí esse é o modelo o mesmo precisa fazer uma regravação na bios tenho a máquina de retrabalho mas preciso de uma gravadora e o arquivo , e como saber quail o chip precisa retirar pras poder fazer a regravação algum vídeo ou tutorial ??
  9. @sicaiantena você precisa ter créditos para comprar um pacote de download,veja mais como funciona:
  10. Ontem
  11. boa noite nao consigo fazer download
  12. @Flavioleal muito obrigado pelo link. Vou testar. Hoje é 21/12/2025 tem uns 4 dias que parou de funcionar pedindo autenticação. Vou testar essa instalação. No BTV 13 não aparece mais para download no GetApps Abraços
  13. Olá, estou com um desse mesmo modelo ele estava com solda fria nos IRF e torrou os resistores que são ligado junto dos IRF eu troquei ele e coloquei baterias novas agora só ascende a luz da frente dele do terra alguém pode me dar uma dica ou esquema elétrico?
  14. @MarceloRibeiro94 parabéns pelo reparo e por não desistir. Esse estava complicado.
  15. boa.
  16. Robsom Lilico
    notícia ghhhdhdfh
    hfhdhdf
  17. romaldo47
    flash FIRMWARE - TV MULTI TL066M
    Agradeço ao colaborador Italo que disponibilizou o firmware para tv Multi TL066M, mas infelizmente acho que o problema da minha tv é Hardware ao inserir o pendrive ela só fica em 1% de carregamento e reinicia em um loop infinito, de qq forma agradeço a todos, abraços !!!
  18. Opa likan na área preciso baixar o aplicativo para o b11 como faço ?
  19. Olá pessoal, tudo bem? Estou precisando de uma ajuda urgente. Estou tentando baixar a última atualização de BIOS para a placa-mãe Soyo B550M (modelo padrão, a versão SEM ARGB), mas o link no site oficial chinês está quebrado (retorna erro 404). O arquivo específico que eu preciso é este: SYYLB550M51.zip Versão: B5.1G (Data: 28/11/2024) Eu realmente preciso dessa versão específica para estabilizar meu sistema. Se alguém aqui tiver baixado esse arquivo antes do link cair e puder compartilhar, eu ficaria eternamente grato! Muito obrigado pela atenção!
  20. Coloco a senha, mas não entra.
  21. Sim, mas não entra. Não consigo acessar, depois de colocar a senha. E vc?
  22. O MEU TA PEDIDINDO SENHA E COM UM QR CODE DO LADO ... O DE VCS TA ASSIM ? @Flavioleal @Apolyelson
  23. O DE VOCES FICA PEDINDO SENHA ? COM UM QRCODE DO LADO ?
  24. Encontrei o manual da placa e descobri que apesar do fabricante ter colocado 2 portas DVI-I apenas uma fornece sinal analógico. Então isso explica o motivo dos pinos analógico do conector DVI-1 não estarem ligados a nada. Então é uma caracteristica desse modelo e a placa não apresenta defeito.
