dica Gravador Novas Bios 1,8V com TL866 e outros [Testado]
robertoes
hi, first of all check and re-check de conections of your adaptor, maybe u forgot something, also u need to select the ic manualy and unmark the check id option, if all is ok try to program a new ic, the adaptor if correct cronstucted works just fine u can be sure of that. Here everytime i got errors the ic was damaged.
Good luck.
So... I never had tryied to read id, just read erase and write, if your cable don't work, and now it is double checked lol, try increase the gauge of the wires, also verify if resistance of your resistors are ok, verify if you don't had wired the clip inverted, check continuity since the clip to the end of cables. Can u post a pic of your assembly?
Good luck.
  Em 05/11/2015 às 22:11, frcf disse:
You must select the ic type choosing a similar one, not try to detect by the program!
Uncheck device id, choose the ic manually (ex: 25Q64FW>try 25Q64FV) and try to read it
If you can read with no error code you will be able to programming the ic
Tried that with different ic's. None worked. Seems that this method just works with some ic's.
Bought this..
